Tiller Tiller for Front Mount Tractor
/ Tiller for Front Mount Tractor #1
hwp
Platinum Member
St. Catharines, Ontario, CANADA
Kubota F2400
A few months ago I enquired about a tiller for my Kubota F2400. I was told that with the exception of Steiner, there was no such thing. So I decided I would try to change that. I bought an old Kubota K420 tiller that seemed to be in quite good shape although it didn't look all that great.
Rear view
This is what it looks like now.
Rear view as modified.
This is what it looks like mounted on my tractor.
This is a side view mounted on the tractor. Some of the modifications I made where the addition of depth runners, parking stands and a hydraulic cylinder to control the angle of the dust flap. Now I need to fine a place to try it out.
/ Tiller for Front Mount Tractor #7
how much did the kubota decal cost you? Just interested..
/ Tiller for Front Mount Tractor #9
What about the direction of rotation? Is the direction the same as it was before modification?
Good question, Jerry. Actually there were two aspects of the drive train that had to be dealt with, direction and speed of rotation. The tiller was designed for 540 rpm ccw rotation. The pto on the tractor is cw roatation at 1100 rpm in low range. I found a 2:1 reversing gear box which I installed between the tiller gear box and the drive shaft. The attached picture is with the shield between the tiller gear box and the reducing gear box removed.
I don't have a place to use it at the moment so I will probably work something out with one of my neighbours to do a test run. /forums/images/graemlins/smile.gif
/ Tiller for Front Mount Tractor #13
<font color="blue"> I found a 2:1 reversing gear box which I installed between the tiller gear box and the drive shaft. </font>
Very nice job! Well done /forums/images/graemlins/laugh.gif
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
78in. Skid Steer Bucket w/ Blade (A65640)
78in. Skid Steer...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2024 ROADCLIPPER HDT207 T/A 22FT TILT TRAILER (A59914)
2024 ROADCLIPPER...
