Tiller for BX1500
/ Tiller for BX1500 #1
Rae10
I am looking to purchase a BX1500 and tiller. Are there other tillers that will work with this tractor other than the Kubota B40C? If so who are the manufacturers?
Thanks! /forums/images/graemlins/confused.gif
/ Tiller for BX1500 #2
Any manufacturer that makes a unit sized for the BX will work. I don't have a BX1500 so don't know the lift spec's etc. but the King Kutter brand has BX specific units that would probably work.
I have a standard King Kutter 48" that i use on my BX1800 and it works. I did have to modify the lift arms to allow me to load on my trailer, but it handles it fine.
I would think the BX1500 is probably more to the tune of a 42" though.
Other mfg's like woods, first choice etc. make units specfically designed for the BX's besides the King Kutter.
Also may want to check out CCM member that deals in tillers.
/ Tiller for BX1500 #3
Tractor Supply Center has tillers and the 1500 will want a 42" tiller because anything bigger would be too much. A cheaper brand might be ok but if it is a long term investment you might want to look at the OEM and see where it shakes out at.
/ Tiller for BX1500 #4
Don't get too caught up in the "proper" size unless the right deal comes along. If you happen to find a tiller that's too wide, you can always take off some tines. You probably only need to be concerned about weight and to some extent, front ballast will help there.
Cheers!
/ Tiller for BX1500 #5
I have a Kubota B7510HST (21 HP engine) and bought a used Yanmar RS1200 rototiller (48" wide, $300) with a 3pt hitch. You can find these at the grey market tractor dealers in your area.
/ Tiller for BX1500 #7
I bought an older Kubota K420 42" tiller and converted it to front mount. It was made in Italy, I think by Muratori. It works great and is well suited to my F2400 (24hp). A slightly smaller unit like the 37" may be a better match for your BX1500. /forums/images/graemlins/smile.gif
/ Tiller for BX1500 #8
The CR45 tiller works fine on a BX1500. Gear Drive, 6 tines per flange, adjustable hitch blocks for Kubota's limited CAT 1 hitch. 10 PTO HP MIN. is needed when using the tiller at maximum depth in clay sod.
/ Tiller for BX1500 #9
CCI, How many tines does your CR45 tiller have? Your web site says 27 ? I figure that's a typo as 6 per flange doesn't work out unless there's a half a flange somewhere.
John
/ Tiller for BX1500 #10
A 6 tine per flange has 3 left tines and 3 right tines. We choose to locate the end flanges next to the end plate in such a manner that the tines only turn in so you have only 3 on the outside flange. This design gives this tiller a better scroll design for this size tiller.
John Deere Metal Sign (A65583)
John Deere Metal...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
3 Brake Drums (A62613)
New/Unused Wolverine 6 Way Dozer Blade (A65583)
New/Unused...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
John Deere 18ft. 3 Point Field Cultivator (A65640)
John Deere 18ft. 3...
