tiller and bush hog sizing ct225 /ck27
   / tiller and bush hog sizing ct225 /ck27 #1
tman1020
Veteran Member
north west indiana
Bobcat ct225 and Bad Boy zero turn
Well i think i am going to pull the plug on a new tiller just not sure if my ct 225 can handle a 6 footer. book says 19.5 pto hp but kioti ck 27 book says 20.5 pto hp. that seems odd to me that they would be 1 hp different in that it seems like the excact same motor guess we will nevr know. either way i think it would handle a 5 foot ok but but would rather a 6 foot my r4 tires are like 5 foot 3 wide. anyone use a 6 footer on a ct225 or a ck27 ??? Also how do these tractors handle 5 foot bush hogs????
   / tiller and bush hog sizing ct225 /ck27 #2
You could probably handle a 5 footer okay but there will be times you may be wishing for more power. If you get a 6 footer, bring your lunch, you will be doing some sitting and waiting for the RPM's to catch up.
   / tiller and bush hog sizing ct225 /ck27 #3
Different machine, but I ran a standard duty 5' brush hog on my 8N, and it had around the same power as you do, but a weaker 3pt, so you should be fine. I tried a 4' model first (neighbor had one not being used), and it was just too small.
Thanks guys I appreciate the info hp ratings on the tillers are kind of all over the place plus I've not seen horsepower ratings on 4 foot or 5 foot Bushogs. I had A 4 footer it won't come close to covering tracks so I sold it before even trying it.
   / tiller and bush hog sizing ct225 /ck27 #5
That size tractor would take a 60" max.. Many tillers are sized at 58".
Engine 29. Have u run a 60 or 72 inch tiller on your ck 30? Or a bush hog if so what size and how did it do
where is all the ck 27 and 225 guys? hibernating????
Well I picked up my new Fivefoot tiller this weekend got a chance to try it out it was definitely the right size didn't seem to bother Tractor at all unless I hit something really really heavy and hard when I was in a turn. otherwise pulled it effortlessly. Tilled Garden so fast had to go look for something else to till so I headed to back area and tilled up about 1/3 ac of weeds in no time. Very impressive chopped up everything first pass. I am happy I went with a tiller insted of a disk.
2018 Laymor SM300 Sweeper (A48837)
2018 Laymor SM300...
2022 Case IH 8250 4WD Combine (A50657)
2022 Case IH 8250...
Grove 4x4 Rough Terrain Hydraulic Crane (A49346)
Grove 4x4 Rough...
2017 CATERPILLAR 938M WHEEL LOADER (A50458)
2017 CATERPILLAR...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
UNUSED KJ 20' X 30' METAL GARAGE (A50460)
UNUSED KJ 20' X...
