till w/2810 HST
   / till w/2810 HST #1
justinbechard
does anyone use a 3 pt tiller on the 2810 HST and if so what size is it. will it handle a 60 inch tiller - the 2810 only has approx. 22 hp at the pto will that be enough, what about using a rotary cutter of 60 inches.
   / till w/2810 HST #2
I would say a 60" tiller and 60" brush mower should work OK.
Thats what I ran on my JD 850 with 22 PTO HP and it worked fine..
   / till w/2810 HST #3
It should run the 60" fine, we generally put a 56" behind the 2810HST, only because that happens to be a size we carry and we don't carry a 60". It handles the 56" with no problems. HST is a great transmission for tilling.
   / till w/2810 HST
thank you very much for the information, as this will be my first tractor. the dealer said it would work just fine but i wanted an opionion from someone who wasnt trying to sell me something
   / till w/2810 HST #5
I have the 2810HST and a 60" First Choice tiller, it works really well. The width w/ R-4's is about 64", so I still have to offset the tiller a little. Power is not an issue in my soil and you can go as slow as you need with the HST.
   / till w/2810 HST #6
I've sold and operated with no problems 2310's with a 62" tiller.
GLaWall
Your Mahindra Tractor Dealer
Batavia, NY
   / till w/2810 HST #7
Justin, I can't comment on a tiller but as far as a rotary cutter goes, I wanted it to at least be the width of my rear tires. You might want to be able to cut up against fences and such. I have a 72" cutter and the 2810HST has no problems with it. I would, however, be interested to know if a 72" tiller would do or maybe a 5 1/2' width if available would seem to be a good fit. Danny
1990 Ford F800 7 Yd. S/A Dump Truck (A48081)
1990 Ford F800 7...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A50459)
2007 FORD F-750XL...
(4) 24' Stand Alone Texas Panels (A50515)
(4) 24' Stand...
2019 Isuzu NPR-HD 24ft. Box Truck (A50323)
2019 Isuzu NPR-HD...
