till w/2810 HST
   / till w/2810 HST #1
justinbechard
does anyone use a 3 pt tiller on the 2810 HST and if so what size is it. will it handle a 60 inch tiller - the 2810 only has approx. 22 hp at the pto will that be enough, what about using a rotary cutter of 60 inches.
   / till w/2810 HST #2
I would say a 60" tiller and 60" brush mower should work OK.
Thats what I ran on my JD 850 with 22 PTO HP and it worked fine..
   / till w/2810 HST #3
It should run the 60" fine, we generally put a 56" behind the 2810HST, only because that happens to be a size we carry and we don't carry a 60". It handles the 56" with no problems. HST is a great transmission for tilling.
   / till w/2810 HST
thank you very much for the information, as this will be my first tractor. the dealer said it would work just fine but i wanted an opionion from someone who wasnt trying to sell me something
   / till w/2810 HST #5
I have the 2810HST and a 60" First Choice tiller, it works really well. The width w/ R-4's is about 64", so I still have to offset the tiller a little. Power is not an issue in my soil and you can go as slow as you need with the HST.
   / till w/2810 HST #6
I've sold and operated with no problems 2310's with a 62" tiller.
GLaWall
Your Mahindra Tractor Dealer
Batavia, NY
   / till w/2810 HST #7
Justin, I can't comment on a tiller but as far as a rotary cutter goes, I wanted it to at least be the width of my rear tires. You might want to be able to cut up against fences and such. I have a 72" cutter and the 2810HST has no problems with it. I would, however, be interested to know if a 72" tiller would do or maybe a 5 1/2' width if available would seem to be a good fit. Danny
2017 HINO 338 BOX TRUCK (A51222)
2017 HINO 338 BOX...
2023 CATERPILLAR 259D3 SKID STEER (A51242)
2023 CATERPILLAR...
2014 International Durastar 4300 Terex BT2047 47ft Crane Truck (A50323)
2014 International...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
Killbros 250 bu Gravity Wagon (A50515)
Killbros 250 bu...
Agco Hesston 4590 Square Baler (A50515)
Agco Hesston 4590...
