Tile shower leak help needed..
   / Tile shower leak help needed.. #11
This is why I will always install one piece acrylic or fiberglass shower/tubs. Water will rot your dreams away and tile jobs all seem to leak at some point.
that is a good point and what i told my wife just the othe day..
We love the look of our custom tile shower, BUT I could do without that leak. LOL
brian
   / Tile shower leak help needed.. #13
For the expense of doing a tile job right, it's hard not to go with a one piece unit.
   / Tile shower leak help needed.. #14
It seems to me that if the tile leaked while it was in warentee then it was never repaired and this is not a new issue, and should be part of that original fix.
If you decide to repair it yourself then determine if its the drain line or the pan that is leaking. Plug the drain with one of those thin rubber sing pads and fill the basin and determine if it leaks overnight. (personally I would add some food coloring to help see the leak.)
   / Tile shower leak help needed.. #15
if you read clear through the link I posted (#3), it explains how to sort out the various possibilities.
We think it should be still considered under the warranty since it was not correctly repaired before.. I didnt understand enough about how it was designed to understand that sealing the tile was NOT a fix, just a patch the first time it was leaking
brian
   / Tile shower leak help needed.. #17
Yes, the grout between the tile is not watertight. The purpose of grout sealant is pretty much to keep it from being discolored in use.
2000 Ditch Witch 3700DD Ride-On Trencher (A55787)
2000 Ditch Witch...
43029 (A51691)
43029 (A51691)
Year: 2006 Make: Ford Model: Ranger Vehicle Type: Pickup Truck Mileage: 86,950 Plate: Body Type: 4 (A55788)
Year: 2006 Make...
34015 (A53421)
34015 (A53421)
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A54757)
UNUSED RAYTREE...
