tightening up hst pedal - sloppy and tractor rolls out forward and reverse
   / tightening up hst pedal - sloppy and tractor rolls out forward and reverse #1
simmysam3
Spokane, WA
TYM 330 HST
Anyone have directions for tightening up a TYM 330-hst (or similar) - preferably with pics - on how to tighten up the slop in the hst pedals. The springs are in tact but its just sloppy and loose both directions and I generally have to press the opposite pedal to kick it back to neutral.
I have seen other posts here, but seems those were just detached springs...
Thanks,
Sam
   / tightening up hst pedal - sloppy and tractor rolls out forward and reverse #2
Before making adjustments, I would follow all of the linkages from the pedals into the transmission and give them a detailed cleaning and lubrication. It is more likely dirt or rust binding things and preventing the return to neutral than something out of adjustment.
   / tightening up hst pedal - sloppy and tractor rolls out forward and reverse #3
The holes in the linkage may be warn or the bushings I've made new parts and replaced bushings in the past when the pedal got to floppy.
   / tightening up hst pedal - sloppy and tractor rolls out forward and reverse #4
I had a similar problem and a few shots of wd40 on the spring solved my sticking pedal problems.
UNUSED RAYTREE RMSG29 - 29" STUMP GRINDER (A51248)
UNUSED RAYTREE...
UNUSED LONCIN FT90 PLATE COMPACTOR (A51248)
UNUSED LONCIN FT90...
2024 KMC 7406 (A53084)
(APPROX 14) 3 1/4" X 6" X 68" THICK IRON BEAM (A51247)
(APPROX 14) 3 1/4"...
Starcraft Starlite 22ft Travel Trailer (A51694)
Starcraft Starlite...
2001 Bobcat 337 Mini Excavator (A51573)
2001 Bobcat 337...
