tightening up hst pedal - sloppy and tractor rolls out forward and reverse
   / tightening up hst pedal - sloppy and tractor rolls out forward and reverse #1
simmysam3
Spokane, WA
TYM 330 HST
Anyone have directions for tightening up a TYM 330-hst (or similar) - preferably with pics - on how to tighten up the slop in the hst pedals. The springs are in tact but its just sloppy and loose both directions and I generally have to press the opposite pedal to kick it back to neutral.
I have seen other posts here, but seems those were just detached springs...
Thanks,
Sam
   / tightening up hst pedal - sloppy and tractor rolls out forward and reverse #2
Before making adjustments, I would follow all of the linkages from the pedals into the transmission and give them a detailed cleaning and lubrication. It is more likely dirt or rust binding things and preventing the return to neutral than something out of adjustment.
   / tightening up hst pedal - sloppy and tractor rolls out forward and reverse #3
The holes in the linkage may be warn or the bushings I've made new parts and replaced bushings in the past when the pedal got to floppy.
   / tightening up hst pedal - sloppy and tractor rolls out forward and reverse #4
I had a similar problem and a few shots of wd40 on the spring solved my sticking pedal problems.
UNUSED JCT 84" HYD GRAPPLE BUCKET (A51248)
UNUSED JCT 84" HYD...
10' CONTAINER (A51248)
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
2016 Godwin CD150M...
2013 Ford Explorer SUV (A51694)
2013 Ford Explorer...
40ft Shipping Container (A52377)
40ft Shipping...
BUSH HOG 7007 LOT IDENTIFIER 104 (A53084)
BUSH HOG 7007 LOT...
