TIG Torch Question
/ TIG Torch Question #1
PHPaul
Platinum Member
Downeast Maine
Kubota B2650 with cab, Pasquali 986
I'm gathering components to try my hand at TIG welding aluminum.
I've been TIGing mild and stainless steel for a while so I'm not a complete newbie, but...
So I ordered the appropriate 1/8 diameter 2% ceriated tungstens and collets, along with some Al TIG rod and new stainless steel wire brushes for cleaning.
Unfortunately, I didn't think about the collet body needing to be upgraded to the 1/8 size as well. I have the appropriate parts on order.
My question is, seeing as I'm just getting started and fully expect to turn a lot of perfectly good aluminum into smoke and scrap before I get the hang of it, can I get away with reaming out one of my 3/32nds collet bodies to accept a 1/8 tungsten (with a 1/8th drill bit), or is there more to it than that?
/ TIG Torch Question #2
When I used to use high frequency TIG to weld aluminum, we use pure tungsten. We put the machine on reverse polarity (like you would stick weld) struck an arc so the tungsten burned up and made a ball on the end. It only take a second to do this. Then put the machine back on straight polarity and you are ready to go.
Pure tungsten makes for a more steady arc than the 2% thoriated or ceriated tungsten when using high frequency.
As for drilling out a 3/32" collet, maybe if you can hold it perfectly straight but I suspect that you will only screw up the 3/32 collet. Just wait till you get the 1/8" and some pure tungsten would be my advice.
/ TIG Torch Question #3
Hello PHPaul,
The 2 percent is probably a red color paint to denote. I always used pure, which is green... when doing aluminum.
You didn't say what style welder you were going to use, just wondering, because a machine that welds mild and stainless won't always do aluminum. Your machine may have a Hi-frequency start for when doing mild steel or stainless, but aluminum requires a full hi-frequency running all the time. (unless things have changed since I did it). You can scratch start stainless or mild steel, not so with aluminum.
Tig welding aluminum requires a little stronger lens to protect your eyes, as the reflection is a little more severe. I used an 11 .
The mild steel you tig is easy to tell when the temperature is getting close to the right temp by the color. Not so with aluminum. You will start heating it, and then apply a lot more power (I used a foot pedal) and then all of a sudden the puddle just falls out of the material. You have to really watch for when it starts to puddle, isn't an easy thing to see at first, when learning.
The size of your tungsten is directly related to what you are welding. You should be able to purchase the correct collet for the size tungsten you are using. Double check to see if they are available in 3/32 also.
The gas will be different also, sometimes. I always used pure argon for aluminum, but when you get really good at it, and want to impress your friends with your welding expertise, grab a bottle of helium. It takes a lot of it, since it floats off very quickly, but it does make the weld look great. (Oh, even with argon, you will have to turn your flowmeter up a little bit more over steel and stainless. I even used a different ceramic tip for the better flow of the gas while welding.
I was able to experiment a lot using different gas and tips due to having a contact with a welding supply company that I did work for. One of my benefits was free gas, and they always gave me any extra's or clearance stuff for free. All I had to do was supply my own bottles, which is why I own so many bottles even to this day.
David from jax
I have an ancient Miller DialArc HF and it does have a constant HF setting.
I have a bottle of pure Argon that I swap back and forth between my MIG welder and the Miller if I'm running TIG.
I also have Red (thoriated) Green (pure tungsten) and Gray (ceriated) tungstens available.
My Miller helmet has a darkness setting that I can adjust.
I did a little aluminum TIG work when I worked at the cannery, but that's been a lot of years and with a much newer machine.
/ TIG Torch Question #6
You can weld aluminum with any of the tungsten you have as long as it's 1/8" but ceriated and lanthanated works best. Pure is going to ball up fast and flutters when the amps get high enough to weld anything over 3/16 thick unless you can adjust the shape of the arc but that only gets you 20-30 more amps. Lanthanated stays clean and is stable plus it's cheaper than ceriated
Just use what you have until you need to buy more
/ TIG Torch Question #7
Remember, Only the Transformer welders require you to Ball your tungsten. Most Inverters will do better with it pointed. When you can run a pointed tungsten, You will have a smaller heat affected zone which means you don't heat up as much of an area as you do with a Balled up tungsten. This lets you do thicker material with a smaller machine. If you have a Transformer machine I'd suggest Pure (Green Tip) But if you have an Inverter I'd suggest 2% Lanthinated (Blue Tip). Almost No chance of boring out a collet but you probably could bore the collet body. Why not just use 3/32 tungsten if you have it. good Luck.
/ TIG Torch Question #8
I have been using the gold. 1.5% Lanthinated. Seems to be doing ok
Well...crud.
Drilled collet body worked okay, but it's pretty apparent that TIGing aluminum won't be added to my skill set any time soon, if ever.
I tried every combination of tungsten (both size and composition), stick out, tip shape, polarity, amperage, and arc length I could think of without success.
I cleaned the aluminum by sanding off the oxidation with new-unused 3M roloc discs, and then wiped it down with acetone.
Problem is primarily two things:
1. I can't see the puddle. By the time I DO see the puddle, it's too late.
2. I shake like a dog passing peach pits and wind up sticking the tungsten into the work. Also makes it difficult to move the torch smoothly.
I never got far enough to try dabbing the rod (started getting mad and quit before doing something stupid) but trying to move the torch with one motion and dab the rod with the other hand using a completely different motion is going to be a challenge.
I haven't given up, but @ 68, I know myself pretty well and I seriously doubt I have either the patience or the persistence to master this one.
/ TIG Torch Question #10
I Don't understand....Your hands should make those same motions when tiging metal.
/ TIG Torch Question #11
Well...crud.
That's why so many profesional welders drink on the job. lol:laughing: It settles their nerves. They can't weld without a can or two in them. Their welds look like chicken litter in the mornings and after lunch a a couple of beers, they settle right in and look like a machine did it.
As a note of advice, try keeping the wire in the puddle(lay wire) and forget the dabbing until you can steady yourself some more (try propping or bracing yourself as well). There are also some TIG "prosthetic" devices that can steady you as well such as the CK "steady grip" if you are committed to this.
/ TIG Torch Question #12
Another option could be to just practice making a puddle and moving it around. Once you get that, You can start adding filler. Best to start on steel or better yet stainless. You will need a mag lens, light or better torch angle too. The 1st thing you need is to be able to see the puddle. Can't weld anything if not. Also curious of your tungsten stick out and if you are using a gas lens or just regular cups.
/ TIG Torch Question #13
Reason I can't figure why he's having problems with seeing the puddle. He says he's been tiging steel and stainless for a while.
Perhaps because the aluminum puddle looks somewhat different than the ss or steel puddles
I don't have a mag lens, but I do wear my reading glassed to help me see it better.
One of the pyrex lens may help as well
Thanks for the tips!
My experience TIGing mild and stainless has mostly been with good, tight joints and just flowing them together, not adding much filler. It's MUCH easier to see the puddle with steel.
I am using ordinary ceramic cups, perhaps a pyrex gas lens would help. I'll have to price them out.
Finding a way to steady my hand will help a lot. When working with steel and no filler, I use my off hand to steady my torch hand. I'll have to rig up a way to work while seated and be able to steady my forearm on my torch hand.
I'm looking through the near section of my bifocals and can focus on the arc pretty well, just don't see the puddle forming.
I'll catch a warmer day where I can work without wearing a freakin' parka and try it again.
/ TIG Torch Question #15
The aluminum doesn't change color. It starts to "sweat" when it is ready. It's fast and quick, and "turbo" speed compared to steel or stainless.
/ TIG Torch Question #16
I think I mentioned the color change not being easy to see. When I learned, my eyes were a lot better, lol. Now that they aren't quite as good, seeing the puddle forming takes a little bit of close watching.
You can (and will!!) do this!
Good luck, and keep after it!
David from jax
It's been single-digits cold for 2 weeks now, and not much relief in sight.
Once it gets back above freezing, I'll get back to work on this skill.
/ TIG Torch Question #18
This puzzles me. TIG is done indoors in a heated shop.
/ TIG Torch Question #20
same here it was 9* this morning ,
Maybe it's these old sine wave machines:D (have a 1962 idealarc Tig 300 300)
i would suggest turning the HF up while (set to continuous)... higher setting helps to break through the oxide,
Machine on A/C and going in (hot) to start the puddle - especially if the aluminum is thick,
3 seconds or less to get a shiny puddle- then back down on the pedal
If that means max power and bury the pedal so be it. If you melt through on a couple test pieces no big deal - just don't let it land on your foot.
the biggest mistake I made with my dinosaur Tig at 1st was using to low of amps to start out with.
To low of amps puts more overall heat in the piece and not enough in a confined area where you are actually trying to (melt) weld.
ps. What kind of hood are you using,
i couldn't see the puddle very well (except for stick) with my old HF auto hood,
When I got my newer inexpensive 4 sensor hood with multiple adjustments it was like night and day for tig and mig.
Hope this helps
2016 Isuzu Box Truck (A60352)
2016 Isuzu Box...
2012 Honda Civic Sedan (A59231)
2012 Honda Civic...
Spreader Attachment (A56859)
Spreader...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
1995 6ft. Wee Willie S/A Utility Trailer (A59231)
1995 6ft. Wee...
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
