bgd8953
Disappointed in the tier 4 engine in the XR4046, a performance issue that was not something I knew about when I purchased 7 mos ago. When running the PTO at 540, the engine runs at 2400rpms, when then regen starts, the engine power is reduced by 50% or limited to 1800rpms, in my case the engine quit, and would not start for quite some time. I had to let it sit, and when I finally got it started, I had to let it idle for 40 mins and let it go through the regen cycle, and I could perform no work during this period. Kinda tough when you have a PTO powered implement on it. I would not recommend this if your using it for farming where your rpms are above 1800rpms for an extended period of time. The unit is in with the dealer for not only this, but steering hyraulic groaning, and a surging trottle. I like the build of the LS, and probably need to step up to a higher HP tractor, in a tier 3 configuration. I'm hoping to work this out with the dealer.
