Tie rod hydraulic cylinders?
   / Tie rod hydraulic cylinders? #1
Ron25
I intend to build a FEL onea these days and have noticed most factory types and even pics here of projects don't use tie rod cylinders. Why?
Checking on prices they seem to be less expensive. Is there a reason they aren't used that much?
   / Tie rod hydraulic cylinders? #2
Ron, Hopefully someone with some hydraulic knowledge will reply but I was very recently working on a Hydraulic top link and that was the first thing that my hydraulic cylinder supply house recommended, I would avoid the ones with the bolts on the outside and go with a welded cylinder but they should work fine. The reason that they are cheaper is bound to be that they make more of them for applications other then us playing around with our tractors hydraulic system.
Steve
   / Tie rod hydraulic cylinders? #3
First of all, what is your definition of a tie rod cylinder? A tie rod cylinder typically has both ends being a clevis with a pin. This design will handle a large majority of applications. There are also cylinders with tube ends and ball and socket ends. Some cylinders have removeable ends that can be changed depending on the application.
However, in general terms there are 2 types of cylinders, welded and non-welded (ie. they have bolts holding them together). The non-welded ones are typically less expensive since they are easier to manufacture. Welded cylinders tend to be used for more heavy duty applications. A FEL, for example, would be considered a heavy duty application and would be using welded cylinders although I have seen some aftermarket FELs using non-welded cylinders.
Welded and non-welded cylinders can have a variety of ends depending on the application. A design engineer is the only one who can give an answer as to why he choose one type over another. In most cases the choice is due to duty cycle, availability and cost considerations.
   / Tie rod hydraulic cylinders? #4
I would also think that welded cylinders fit into smaller places better and have better clearance.
2017 International DuraStar 4300 26FT Box Truck (A51692)
2017 International...
2006 Husqvarna YTH2148B 48in Riding Mower (A51694)
2006 Husqvarna...
1992 MACK RD688S (A53843)
1992 MACK RD688S...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
2025 Big Tex 14GN-40D5A 35ft 6 Ton Gooseneck Flatbed Trailer (A51692)
2025 Big Tex...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
