tie rod ends
   / tie rod ends #1
robert j
mason nh
yanmar 336d
does any body know what the thread size is on the tie rod ends. for a yanmar 336d tractor . I bought a new tie rod set up from hoye tractor and the left hand thread does not thread in . had to start filing the threads with a 30 deg file per side for 60 deg total just for it to start threading it in . I got it to thread in about 3/4 to 1. but very tight bad threading job in the shaft. thank you bob v.
   / tie rod ends #2
I don't warranty it but believe it is m17-1.5
   / tie rod ends
thank you. I just emailed hoye tractor where bought the complete tie rod assembly. my second house is 2.5 hours away from where I live that's where the tractor is the right tie rod threaded in fine but the left would only thread in about a 1/4 of a inch. boy was I pissed off 3. hours home the dam leaf peepers clogging up the highway. what the **** will a left hand tap and die cost me . hey thanks for the info .some where to start msc industrial here we come thank you bob.v
   / tie rod ends #4
I am sorry you are having problems with your tie rod. Those tubes are made for us by a local machine shop that typically does very good work. I guess you are sure that it is not a ding or something on the male tie rod thread that is causing the problem? I have not had any other problems with the tubes but we can certainly switch it out for a good one if you would rather. M17 1.5 LH is a very uncommon thread.
   / tie rod ends #5
I don't warranty it ....
But it looks like Hoye will, standing behind their product as one would expect.
Yep, surely irritating when one gets a rare defective product but such is the nature of human endeavors. It's the vendor follow-up that makes the difference and that's another of the reasons that Hoye has earned a great rep, IMHO.
   / tie rod ends #6
Did you compare the thread pitch with the old end, and does the old end still screw in??
PT 8' Offset Disc (A50121)
PT 8' Offset Disc...
2018 Kubota R530 (A50120)
2018 Kubota R530...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
John Deere 4020 (A50120)
John Deere 4020...
2005 Chevrolet Colorado 4x4 Pickup Truck (A51692)
2005 Chevrolet...
Deutz 6806 (A50120)
Deutz 6806 (A50120)
