tie rod end
   / tie rod end #1
slammer3364
Bronze Member
Jinma 284
Anybody have any tips on getting tie rod end off Thanks
   / tie rod end #2
Little more info...off what?
   / tie rod end #3
Assuming from where they're into a tapered part with nut on end where the rotation takes place? They have tools for that. If you don't need to keep the tie rod intact, there's a forked tool that you drive in to separate the pieces. If you need to keep the tied rod and seal intact, they have a tool that is put over the rotation part and has a bolt that can be rotated to push the threaded part of the tie road out. Most auto parts stores would have these on sale or rental.
Be sure and precisely measure or could the # turns to remove the tie rod from the rod that goes between the wheels so that the alignment will be the same. This is after you have the other part extracted.
Ralph
   / tie rod end #4
If you're attempting to remove the tapered end from the boss, if you give the boss that the taper goes thru a good smack with a BFH it'll usually pop off. Hasn't failed me yet LOL...............Mike
   / tie rod end #5
Yep, remove the nut, hit the part that the rod end bolts thru. A basic jaw puller clamped across the top of the threaded end to put a little force on it makes the smack method nearly foolproof...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A53472)
Michelin CARGOXBIB...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
HAMM HD+ 120I DOUBLE DRUM ROLLER (A51246)
HAMM HD+ 120I...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2015 Linde H35D 4,350lbs. Diesel Forklift (A51691)
2015 Linde H35D...
2021 JOHN DEERE CP690 LOT IDENTIFIER 182 (A53084)
2021 JOHN DEERE...
