tie rod end removal on L3600
   / tie rod end removal on L3600 #1
double hunter
Ford 1715
Trying to remove the tie rod ends on a Kubota L3600, when I try and back the nut off holding tie rod end the nut and bolt are turning, am I overlooking something or is there a trick to removing the tie rod end,
   / tie rod end removal on L3600 #2
The taper of either the steering arm or the tie rod end is worn. Your best bet is a nut splitter. When the nut is off you will have to determine if a new tie rod end will be tight in the tapered bore or if the part that is bored will have to be replaced also.
Good luck. .. .
Smilinjak :)
   / tie rod end removal on L3600 #3
Good luck. .. .
Smilinjak :)
As smilinjack says, the taper is worn, likely from the rod end being loose. You could try tightening the nut to wedge the shaft more tightly in the taper, then back off the nut. If that doesn't work, then it's cut it off.
   / tie rod end removal on L3600 #4
grinder with a cut off wheel. cover any painted surfaces or the cuttings / filings will stain them with rust overnight.
PALLET OF 15- 5 -10 TURF FERTILIZER (A51244)
PALLET OF 15- 5...
2018 Dodge Journey SUV (A50324)
2018 Dodge Journey...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
2014 Ford Transit Connect Van (A50323)
2014 Ford Transit...
