Tie Rod / Ball Joint Assembly on Cub 2554
   / Tie Rod / Ball Joint Assembly on Cub 2554 #11
When my ball jts went bad I bough a few rod end bearings from my local Timken bearing store.their left hand or right hand threaded 3/8" and you put a 3/8" bolt thru the end.The best thing about them is that they are greasable and a lot heaftier than the Cub parts. And less than 5 bucks each .See Mcmaster parts- McMaster-Carr
Is this the end you are talking about McMaster-Carr and i need a right and left hand thread right?
   / Tie Rod / Ball Joint Assembly on Cub 2554 #12
If your tie rods have left and right hand threads that's what you need..
   / Tie Rod / Ball Joint Assembly on Cub 2554 #13
are these the ends that you used? I should need two right hand and two left hand to replace all four correct?
   / Tie Rod / Ball Joint Assembly on Cub 2554 #14
You need to check what size thread is on your current tie rod ends. MTD used several different parts thru the years part#723-0448A has a 7/16"-20 female thread and 3/8"-24 male stud, #723-3018 has 3/8"-24 male and female threads and 723-0156 has the 3/8" threads but the stud is longer.
2017 VOLVO VNL TANDEM AXLE SLEEPER (A58017)
2017 VOLVO VNL...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
Liebherr PR736 LGP Crawler Dozer, S/N & PIN# 1155-17697, ID# 93501138, Turbo Diesel Engine, 13' (A59076)
Liebherr PR736 LGP...
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
2020 CATERPILLAR 299D3 XE SKID STEER (A52709)
2020 CATERPILLAR...
1977 Ford F-100 Super Cab Pickup Truck (A56858)
1977 Ford F-100...
