Tickle chargers
   / Tickle chargers #1
kongmen
Bronze Member
Columbus OH
L3600 Kubota
Those of you who use these on your tractors do you remove the tractor cables or just put the leads on with the battery cables still hooked to the battery?
   / Tickle chargers #2
I have wired in quick disconnects to the terminals that are right below the edge of the platform, so I don't have to swing the battery box out to hook up the trickle charger. This battery is going on 4 years.
hugs, Brandi
   / Tickle chargers #3
Get yourself a batteryminder that desulphates. They come with quick disconnects and you will be happy.
   / Tickle chargers #4
To answer your question, you can leave the battery cables on the battery when you hook up the battery maintainer... There might be vehicles out there that this statement might not be true, but I have never found one yet. I have three maintainers humming out in my barn right now. One on my mowing tractor for the winter, one on my Dodge Cummins, and one on my JD 2250, since I have only had to fire it up once this winter to blow snow.... :(
   / Tickle chargers #5
Ditto,,,,,,,,,,,,,,,,,,Just hook up battery tender/maintainer leads to battery posts, leave battery cables as is................
   / Tickle chargers #6
Tickle chargers
I thought maybe someone came up with a new type of charger, you just "tickle" your battery if it dies :laughing: Could not resist.
I do have a cheapo trickle charger from HF that I use in the cold months, works great just hook the clamps and plug in.
   / Tickle chargers #7
ditto that. on the tickle charger. i thought it might be a new exciting option out there :)
ditto on not removing cables. nothing should be drawing anyway.. and if it is.. it's eaither minscule like for radio memory.. or it's something that needs to be fixed.
soudnguy
   / Tickle chargers
Thanks for all the replies. The TICKLE charger is the latest new fangled addition so I had to be sure. :laughing:
   / Tickle chargers #10
I have two of these, would highly recommend them.
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
PRINTER (A53843)
PRINTER (A53843)
2012 Ram 1500 Quad Cab Pickup Truck (A53422)
2012 Ram 1500 Quad...
Mohawk 12,000lb Two-Post Electric Auto Lift (A54811)
Mohawk 12,000lb...
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
