Ticking in the seat/hitch area
   / Ticking in the seat/hitch area #1
queen of spades
Hi all,
I'm starting to notice a light ticking noise coming from the back of the tractor. It's most noticeable when I have my head right by the back of the seat, above the hitch arms. The sound isn't very loud, but I don't think it's been there before. My oil levels are good, and I change the oil & filters regularly.
Any ideas on what it could be?
no ideas at all?
is the ticking sound normal and am I worrying about nothing?
   / Ticking in the seat/hitch area #6
Could you give us more info. Does it do it all the time,Only when the pto. is engaged.Etc.
   / Ticking in the seat/hitch area #7
Is that something I need to have looked at?
ONE: Do you have an overrun clutch on the end of your pto shaft?
If not, that is not the problem.
TWO: If you do, then it is very easy to remove the overrun clutch and see if the ticking stops.
Let us know if you have one and ,if so, if you removed it and the ticking stopped.
   / Ticking in the seat/hitch area #8
no ideas at all?
Like the guys are saying, try different combinations in the controls while static to determine the cause of the sound. For example, in each range gear with the trans in neutral. Could also be a range, gear or PTO gear selector being in neutral, but not completely out of the way. A 'ticking' sound from the PTO ORC (OverRun Clutch) is normal, but only happens when the PTO driveshaft is turning and the PTO shaft is not driving, like when you're brushhogging, and you stop, in neutral with the pto in neutral, or clutch 'in'. I hope you're not having your head near the PTO or shaft if it's spinning - not to assume you have long hair. PTO accidents can be remarkable in their brutality.
I think it is good that you're paying attention to new sounds. Many times I've tended to a 'new sound', it paid dividends with catching a problem before it got critical.
2017 HITACHI ZX350LC EXCAVATOR (A53426)
2017 HITACHI...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A54313)
2012 INTERNATIONAL...
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2014 DRAGON...
2008 BMW 535xi AWD Sedan (A53424)
2008 BMW 535xi AWD...
