Backhoe Thumbs are handy but......
   / Thumbs are handy but...... #1
CurtisC
Elk Park NC
Kubota B26TLB
Back in 2014 I installed a mechanical thumb on my B26TLB and proceeded to use it for grappling logs and rocks. Fast forward to yesterday when I installed a new $700 bucket. The B26 TLB is a pretty rugged little machine capable of taking a lot of abuse and I initially assumed the bucket curl closing power would not overpower the structural integrity of the bucket or thumb - bad assumption. A large rock with its irregular shape can require a lot of closing force to pick up and unless you're paying close attention you can apply way too much force on the small ones as well. The bucket curl cylinder apparently has the power deform the structural tube at the top of the bucket. After the deformation became apparent I became a lot more cautious when working with rock but damage eventually got worse resulting in cracks at the welds to support brackets. I could weld up the cracks but there wasn't any practical way to straighten out the bucket. Fairly certain it was picking large rocks with the thumb that was the culprit for me but be careful when closing against any immovable object.
View attachment 679635View attachment 679636View attachment 679637
   / Thumbs are handy but...... #2
The pictures won’t load. Was it an after market bucket?
The pictures won稚 load. Was it an after market bucket?
Sorry, tractor is a 2009 and the bucket is the original that came with it
   / Thumbs are handy but...... #4
Pretty easy fix. And certainly cheaper to fix than replacing it. I`ve seen alot worse that got fixed.
   / Thumbs are handy but...... #5
Not everybody looks at things the same, but an hour in the barn with a grinder and some 7018 welding rod, and put it back to work... unless the damage is more significant than the pictures can show clearly. I've seen worse, and fixed it, and put it back to use.
   / Thumbs are handy but...... #6
An hour?
You and I have very different work speeds!
   / Thumbs are handy but...... #7
Junk send it to me its just in your way now..........:D
   / Thumbs are handy but...... #9
Kind of having a real stong grip and brittle bones.
   / Thumbs are handy but...... #10
It looks to me like you’ll need to cut the ears off for re use and then cut and replace cross tube. It’s fixable but it would take me a lot more than an hour. Or you could probably press it straight ish and keep using it which is what I would do.
2015 Ford F-250 Liberator 3200 1.5 Ton Crane Service Truck (A55852)
2015 Ford F-250...
1986 Hobbs Cone Star 35' Dump Trailer (A56469)
1986 Hobbs Cone...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A57024)
2008 Ford F-250...
2017 JCB 510.56 10,000lb 4x4 Rough Terrain Telehandler (A55851)
2017 JCB 510.56...
Honda Pioneer SXS700 4X4 Utility Cart (A55758)
Honda Pioneer...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
