Thumb for KB2375
/ Thumb for KB2375 #2
I installed one last spring and I'm not sorry. I have not found it as usefull as I anticipated. I find myself doing things with my forks that I bought the thumb for. Next year I have a lot of rocks to move so I'll get more use out of it
/ Thumb for KB2375 #3
That log looks pretty heavy. Do you worry about tearing out your front diff./axles with a load like that? I guess if it will pick it up it's ok to carry? What do you base your judgement on? Just curious. That looks heavier than a bucket load of dirt or gravel. I have noticed other threads about loader cracks, wonder if this could be why.
/ Thumb for KB2375 #4
As long as you can carry it safely without upsetting the machine- YES, it should be fine.
The cracked loaders you read about are cracking because of a design flaw, nothing more/nothing less.
/ Thumb for KB2375 #5
That log looks like maple, which is not too dense. If it was locust or hickory, he probably couldn't have lifted it.
I carry logs with my bucket and grapple quite often. I couldn't lift an 18" x40' red maple with my DX 29 and had to cut it, but all the little stuff I usually deal with is no problem. I generally don't have room to maneuver anything much longer than 10 feet. I have a homemade set of 10" teeth on the bottom of the bucket that help a lot.
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
20ft Jumper Cables (A65583)
20ft Jumper Cables...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2017 Loat 22ft Tilt Trailer (A59231)
2017 Loat 22ft...
Cedar Boards (A65640)
Gehl Mix-All 95 Grinder Mixer (A64047)
Gehl Mix-All 95...
