Throttle wont stay open.
   / Throttle wont stay open. #1
Beemanfarmboy
Ford 841 w/p steering
bought a Ford 841 for my son and I to have some fun with. We're tackling a problem with the throttle now. Throttling up we have to hold it open or it springs back to idle. Linkage up front seems ok but at rear there is a tab that the forward rod attaches to that points to the rear that has a hole in it, it look like it at one time either had a spring attached or maybe a thinner rod . There is also a metal tab attached with a loop bent in it behind and under the air filter that looks like it may have had a rod or spring or both that is at the same elevation as the tab with the hole in it. I'm finding the fellow I bought it from , who was the original owner did a fair amount of Jerry rigging to it, so there's stuff not there anymore. Can anyone help?
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
Kraus Drive Over Fertilizer Conveyor (A50514)
Kraus Drive Over...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
71060 (A49346)
71060 (A49346)
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
PORTA CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTA CABLE 150...
