Throttle wont stay open.
   / Throttle wont stay open. #1
Beemanfarmboy
Ford 841 w/p steering
bought a Ford 841 for my son and I to have some fun with. We're tackling a problem with the throttle now. Throttling up we have to hold it open or it springs back to idle. Linkage up front seems ok but at rear there is a tab that the forward rod attaches to that points to the rear that has a hole in it, it look like it at one time either had a spring attached or maybe a thinner rod . There is also a metal tab attached with a loop bent in it behind and under the air filter that looks like it may have had a rod or spring or both that is at the same elevation as the tab with the hole in it. I'm finding the fellow I bought it from , who was the original owner did a fair amount of Jerry rigging to it, so there's stuff not there anymore. Can anyone help?
2005 Ford F-250 Crew Cab Pickup Truck (A46684)
2005 Ford F-250...
24ft Corral Panel w/ 12ft Gate (A49251)
24ft Corral Panel...
2016 Ford Transit Connect Cargo Van (A46683)
2016 Ford Transit...
New Holland 258 Hay Rake (A49251)
New Holland 258...
2015 Ford F-250 4x4 Super Duty Ext. Cab Pickup Truck (A46684)
2015 Ford F-250...
2015 Dodge Ram 1500 Crew Cab Pickup Truck (A46684)
2015 Dodge Ram...
