Throttle Speed Advances By It Self
   / Throttle Speed Advances By It Self #1
1963Deere3010guy
As far east in Georgia as you can get with out get
1963 JD 3010 NFW
Greetings,
I am not saying the throttle lever moves by it self, but I mean the engine RPM will increase all by it self. If you move the throttle lever all the way to wide open very quickly and pull it back the engine RPM will stabilize to normal. There is no patter that I can fix as to what could be causing this. I just bought it and the former owner say it has done it all it's life. If any one could shed so light on this I would be greatly appriciative.
Buy the way this is a one owner/family tractor.
Thanks,
Joel
1963deere3010guy
   / Throttle Speed Advances By It Self #2
Does the tractor have a governor? If so I'd look there. Try lubricating the linkage first and then check for smooth operation of the weights, worn binding spool or worn shaft. Keep us posted and good luck.
   / Throttle Speed Advances By It Self #3
Is this tractor the 3010 in your profile? If so is it gasoline or diesel? If diesel it's probably the governor in the injection pump is bad.
Hello Folks,
As a follow up, I checked with a local diesel shop and they told me it was probably the advance weight plate broken. They quoted me $600 dollars to overhaul it and said it would take them about 2 days to do it.
1963deere3010guy
   / Throttle Speed Advances By It Self #6
I am no injector pump specialist but would want to know if this problem might cause a runaway engine issue if left as is? Hopefully some one more knowledgeable will respond to this.
With many years on an injector pump a rebuild can be worthwhile and allow you many more years of use.
   / Throttle Speed Advances By It Self #7
I have never seen a RoosaMaster pump like this cause a runaway engine. It can give that impression as it revs on it's own. The one thing I can say is the longer you run it like this, the more expensive the repair will be. Sometimes the repair can exceed the price of a complete reman pump.
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2012 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
2008 CATERPILLAR 325DL Long Reach (A52384)
2008 CATERPILLAR...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
