Throttle Slipping
   / Throttle Slipping #1
JohnInAla
Grand Bay, AL
Yanmar YM2000
My YM2000 is running great, but the throttle lever slowly creeps back decreasing RPM. I checked the owner’s manual but could not find an adjustment. It looks like I could tighten the nut on the lever assembly to create more friction. Is this the right way to adjust?
Thanks, John
   / Throttle Slipping #2
You are correct. It has a double nut lock. You loosen the outer and tighten the inner. Then retighten the outer to keep it from loosening. I always put some lube on it before and after adjusting.
   / Throttle Slipping
Thanks kayssupply, that's what I thought.
John
   / Throttle Slipping #5
My Yanmar Ke3d had the same problem. I had to take the steering wheel off to then take the dash off to get to the mechanism. It too has two nuts and a friction washer like the others described.
Mark in PA /forums/images/graemlins/smile.gif
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
John Deere WG48A 48in Walk-Behind Mower (A51691)
John Deere WG48A...
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A53426)
2019 TEREX PHOENIX...
UNUSED FUTURE HYD WOOD DRILL (A51248)
UNUSED FUTURE HYD...
2015 TAKEUCHI TB290 EXCAVATOR (A51246)
2015 TAKEUCHI...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
