Throttle plate screws missing on Kohler engine
   / Throttle plate screws missing on Kohler engine #1
grabbit
John Deere D130
I have a JD STX38 with a Kohler engine. The engine suddenly went full bore and shut it down and found the throttle plate disconnected inside. I do not see the screws. Do I need to pull the engine apart to get them out before firing it up again? Or can I get two new screws and move on?
   / Throttle plate screws missing on Kohler engine #2
I'd pull the head and have a look see.
when putting head back on, how much torc should applied and any particular pattern? Any engine diagrams out there on web?
   / Throttle plate screws missing on Kohler engine #4
What model Kohler, I have numerous service manuals.
Andy
   / Throttle plate screws missing on Kohler engine #6
Those screws can bang around in a cylinder, ask me how I know. It may be a pain, but get them outta there or risk major damage, which would be a real pain. This was a B&S 15 horse riding lawnmower in my case, but the principle's the same. I didn't find out about it until the thing went full bore and made a heck of a racket while I was mowing.
Good luck.
   / Throttle plate screws missing on Kohler engine #7
I agree. Find those screws. They may be pounded into the top of the piston.
When I was a kid my older brother lost a wing nut into the intake of a turbocharged engine. He figured it would "work its way out". It did, after it took out the vanes in the turbo and they in turn took out the engine.
   / Throttle plate screws missing on Kohler engine #8
Look in the muffler first.
Engine model is a Kohler CV13S
Removed plug..did not see anything. Looked up muffler, nothing.
   / Throttle plate screws missing on Kohler engine #10
Look at the point of entry, intake, under intake valve, cyl., in the exhaust valve. If not there, you got lucky.
Guard Rail Pieces (A51692)
Guard Rail Pieces...
UNUSED Roof Thermal Insulation (A53117)
UNUSED Roof...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
2007 Volvo VNL Truck Tractor (A53473)
2007 Volvo VNL...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53473)
2019 Krause...
2018 Hino 155 16FT Cab and Chassis Truck (A51692)
2018 Hino 155 16FT...
