Throttle moves to idle
   / Throttle moves to idle #1
willis2004
Darby, MT
2001 New Holland TC33D
The throttle on my 2001 TC33D won't stay at the set RPM. It moves back to idle within a few seconds. Is there an adjustment on the throttle and if so how do I get to it. It looks like most of the plastic has to come off to get to that area. Thanks for any help. Willis
   / Throttle moves to idle #2
yes it does. Found out after adjusting our tc25 10 times, a bungee cord is the best solution. even the dealer told us it was a flaw in design.
   / Throttle moves to idle #3
It is just 4 bolts, 2 on the firewall and 2 below the steering column. Move the plastic shield to access the bottom of the throttle lever. Won't take 5 minutes to tighten the resistance nut on the throttle lever. I would consider putting a locknut behind the adjustment nut and adjust it on the tight side.
Thanks for the help. I fixed it yesterday. I even had a lock nut that fit the bolt, so I put it on. It was a quick job.
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2023 Sundowner Rancher Express 24FT Livestock Trailer - All-Aluminum Stock Hauler (A55302)
2023 Sundowner...
2005 FORD F-150 XL (A58214)
2005 FORD F-150 XL...
(UNUSED) WESTERNDORF 4200 BRUSH CRUSHER GRAPPLE (A52708)
(UNUSED)...
John Deere 5105M (A53317)
John Deere 5105M...
2025 Wolverine SP-15-84W 84in Snowplow Skid Steer Attachment (A55973)
2025 Wolverine...
