Throttle Handle keeps looseing on TC-35
   / Throttle Handle keeps looseing on TC-35 #1
navyjoe
Eastern Tenn
Kubota BX2380 and L2501
My trottle handle will not stay tight on its shaft. Consequently I have to always use the foot level to try and maintain RPM. I can tighten it by getting a wrench thru the hole, but it just loosens back up. Does it use lock tight on that nut to keep it in place?
Second question, to get to the nut and try and fix it, what is the proper way to get the shrouds off to gain access? All I can see are 2 bolts in a rercessed area below the steering wheel that bolt the 2 black pieces together. The rest is hidden. Are those the only thing that hold it. Seems too simple.
   / Throttle Handle keeps looseing on TC-35 #2
I either loctite the throttle tension nut, or double nut the bolt. It takes a 10mm nut if you choose to double nut it. I have probably done a couple dozen tractors over the years. Remove the two bolts you have found at the rear of the cowl, then open the hood and remove two more that screw into the front edge of the black cowl piece.
Thanks for the help, just what I needed.
2014 International DuraStar 4300 Street Sweeper Truck (A52377)
2014 International...
2017 Vactor RamJet Sewer Jetter Trailer (A51691)
2017 Vactor RamJet...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
2020 Bell TC-11A Crawler Carrier (A52384)
2020 Bell TC-11A...
2022 Ford F-150 Pickup Truck (A51692)
2022 Ford F-150...
