Throttle for shuttle shift
   / Throttle for shuttle shift #1
billfires
Southeastern Mass
New Holland 1920
Does anyone with gear transmission(especially "shuttle shift" types) use the hand throttle instead of the foot pedal when using the FEL? Specifically I mean similar to a HST trans. whereby you set the hand throttle. I haven't tried this with my NH 1920 but would be interested in others opinions. Thanks for any thoughts or ideas.
Bill C
   / Throttle for shuttle shift #2
Billfires I have one but only use it when using my backhoe
or warmming up the tractor other than that I like to have control of speed but I don't cut grass or any long drives with out stopping
Ed, thanks for your reply. I just edited my post and added when using the FEL. Thanks again.
Bill C
   / Throttle for shuttle shift #4
I have a 1920, and set the hand throttle for idle, and use the floor throttle for anything but ( plowing, seeding, discing, mowing ).
No fel though.
Soundguy
   / Throttle for shuttle shift #5
The only time I use the foot throttle is during road transit, or sometimes when I am mowing and going up a hill I will use it to keep the rpm's up. Other than that I use the hand throttle for just about everything.
   / Throttle for shuttle shift #6
I use the hand throttle for most everything. I don't have an FEL /w3tcompact/icons/frown.gif or I might use the foot throttle more.
   / Throttle for shuttle shift #7
Yes, I occasionally use the hand throttle with the FEL. When I am turning the manure pile, I will kick the hand throttle up a notch or two so that the FEL will move quicker when I step on the clutch. That way my focus is on the FEL controls and not on the throttle.
I will also use it if I am operating near a drop off. I have a burn pile set up in a field just below an outcropping of ledge. Because of the drought conditions, the pile is getting pretty big. I often get my front wheels right on the edge when I am am trying to add to the pile. So when I back away, it can't roll over the edge.
//bruce
   / Throttle for shuttle shift #8
Bill,
I have a 1720, 12x12 w/shuttle and I always use the hand throttle. With the clutch, brakes, shuttle, and loader valve its just one less thing to worry about for me. Sometimes I feel like drummer, if I just had some cymbols....
   / Throttle for shuttle shift #9
That's what it's there for.
   / Throttle for shuttle shift #10
I will try to revive this thread instead of creating a new one. None of what I'm asking here involves using the PTO.
I was playing around with my tractor today and decided to use the foot throttle more since I've never bothered with it (always used the hand throttle and my dad's old Massey only has a hand throttle). I was using the FEL a lot and used the foot throttle to control ground speed, not power since I was only moving brush around. I found that in 1st or 2nd gear, using the foot throttle gives me more delicate control when I need it, but also lets me speed up a little bit when I want it. Also, I like to reverse around idle speed (without a load) since otherwise it's WAY TOO FAST. I can also go into 4th (in low range) and rev up for decent speed but let it down to idle and I'll creep along happily.
Is this hard on the motor?
Later on I went into the woods and since I was going up/down slopes more I set the hand throttle around 1200 rpm and used the foot throttle some when I wanted to speed up again. In only a few instances did I use the foot throttle for the purpose of powering the FEL, and at those times I was either stopped or already pushing against something like a big rock.
I just wanted to check mainly that I'm not going to prematurely wear out my engine by using the foot throttle to rev up and down like this. At no time did I rev it past 1800 or so, and I use the pedal gently. I never lugged the motor (even in 4th at idle) but I'm just slightly paranoid that by not setting the motor at a particular rpm and leaving it, I'm shortening the life of my engine.
Tried searching and several threads came back but none addressed my specific question.
Thanks!
2003 Pierce Spartan Pumper Fire Truck (A51692)
2003 Pierce...
2007 Volvo VNL Truck Tractor (A53473)
2007 Volvo VNL...
2015 Case 580N EP Loader Backhoe (A53117)
2015 Case 580N EP...
2011 Nissan Maxima Sedan (A53424)
2011 Nissan Maxima...
2013 PETERBILT 367 (A53843)
2013 PETERBILT 367...
