Throttle cable part 2 - not holding speed
   / Throttle cable part 2 - not holding speed #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
So I have replaced my throttle cable. It was in pretty rough shape and just bought the replacement a few years ago.
Problem is that it won't hold throttle. When I tighten it down it becomes impossible to move, but when I loosen it it vibrates out of my desired RPM setting. Would love solutions. Was mulling over a replacement idea as I cannot quite figure this out.
   / Throttle cable part 2 - not holding speed #2
Is there enough slack in the cable to make a loop in it? That would increase the friction...
It is only friction inside the cable housing and at the control lever that holds it in place.
   / Throttle cable part 2 - not holding speed #3
Carl, Have you tried lubricating the throttle lever? Getting it greased can enable you to tighten the nut on the lever so that it doesn't vibrate loose, but still be able to move it easily. I had to do that with my 1445. YMMV...
All the best,
Peter
Good idea Peter. I fly home on Sunday so will get into it.
2023 Kubota RTV-XG850 Sidekick (A55315)
2023 Kubota...
2007 Ford F750 (A55973)
2007 Ford F750...
2011 Ford F150 Ext. Cab Pickup Truck (A55973)
2011 Ford F150...
2009 Dodge Ram 3500 Flat bed (A55973)
2009 Dodge Ram...
2003 Big Tex 10PI...
2018 Cadillac Armbruster 70IN Limo - 43,279 Miles, Professional Coachwork, Clean Executive Vehicle (A55315)
2018 Cadillac...
