Three point sprayers
/ Three point sprayers #1
Ortie
Carleton,MI
Kubota B2400
I have a little over five acres. About two acres are lawn. The balance is last year's corn stubble, with weeds growing in it. About half of that I have been able to mow with my Kubota B2400 with belly mower.....until the recent Michigan rain started about three weeks ago. If it ever dries up, I hope to catch up by mowing the portion that has not yet been mowed, that has very tall weeds, then start over and mow the whole weed field. I am researching a three point sprayer that I can use to spray 2-4-D on the yard and field. The questions are; how big a tank, boom or boom-less sprayer, any suggestions on brand, PSI, etc. I want quality equipment that will last and give me the most for my buck while getting the job done efficiently.
/ Three point sprayers #2
I just purchased a Schaben sprayer and couldn't be happier with my purchase. I purchased a 60 gallon 12 volt sprayer with a 7 nozzle boom to fit in the back of my Gator. The whole sprayer is built really well and the pump is great. Best of all it was made in the USA. Here's a link to their 3 point sprayers. They have one that is 55 gallons with different boom selections to pick from that would work well with your B series Kubota. Here's the link: Schaben Sprayers
/ Three point sprayers #3
I have a 10 foot boom sprayer that I picked up at the local New Holland dearlership. It doesn't have a brand name that I can see. I have had it for 10 years. For what you describe, I would think a generic sprayer with a 55 gal tank would work. The 10 foot boom is nice, but you could probably get by with a smaller 3 nozzle 5 or 6 foot spray. You definitely want to get a hand gun. You can't use that for 5 acres, but you will be surprised how often you use it on fence rows, etc. I spray a much larger area than 5 acres. There is really no need to get a "premium" priced sprayer. They all use the same pump, which I have replaced once (last year), same nozzles, etc. You can adjust the amount of spray easily. If you have an area that you know the size of, it is very important to learn the psi needed to cover say a couple of acres with the 55 gal tank along with the ground speed and engine rpm's you are using. Once you figure that out, read the label on the 2 4 d, mix it up, and go for it. As a side note, I have been unimpressed with 2 4 d by itself. I use Strike 3 or 3 Way...which has 2 4 d along with a couple of other weed killers. A fall and spring preemergent plus generic roundup right on your grass areas in January (yes roundup....won't kill the grass that is dormant and has no prolonged effect) will work much better for you. That is no help right now, but think about it in October! BTW, a 3 point hitch PTO driven sprayer on your tractor is much better than the 12 volt type. No disrespect to Dishpointer, but I use one of those occasionally at my church and they are a lot more trouble to use IMO. Good luck and have fun. Just remember that you need to be VERY diligent about rinsing the sprayer out after EACH use. That cleans the nozzles and gun as well as the pump and mixers. Take off the strainer down below and clean it as well and leave it off during the winter and the gun line drained as much as possible with the gun nozzle locked in the open position for winter storage.
/ Three point sprayers #4
Look at an Ag Spray 3 point hitch sprayer. Get the biggest tank your tractor will handle. Most of the spraying time is traming back and forth to refill. The one I bought does not have a boom but rather one nozzle on the back that sprays a path 20 ft. wide and does have a gun. That way you don't have to worry about tearing off a boom.
/ Three point sprayers #5
Any of the basic sprayers will do well. they are just a tank with hoses out to the nozzles. nothing very complex. The Hypro pumps work fine just make sure you get a least a five roller pump for capacity to build adequate pressure.
I like my boom sprayer - it spans about 12' so I spray about 15' each pass. This seems just about right for a variety of jobs on a small acreage - from the front lawn to the pasture out back. My booms are spring loaded so that if I hit a tree or fence post they break away and are not damaged - this is a very common feature.
55 gallon tank minimum - bigger if reasonably priced.
2013 Polaris Ranger 400HO (A66408)
2013 Polaris...
2024 CATERPILLAR CP56B PADFOOT ROLLER (A65053)
2024 CATERPILLAR...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
METAL GRAVITY WAGON (A64278)
METAL GRAVITY...
GREAT PLAINS 2400 TURBO CHOPPER (A64278)
GREAT PLAINS 2400...
Landhero Backpack Leaf Blower (A66408)
Landhero Backpack...
