3-Point Hitch three point linkage
   / three point linkage #1
roy49
Anyone ever had any trouble with the little gear box that raises and lowers the right hand lift arm on a 4630? The crank handle works fine but the gearbox right above the lift arm will only turn about half a turn. There is no locking latch and the gearbox seems to be a sealed unit. Anyone ever had this problem?
Thanks
Roy
   / three point linkage #2
sounds like a broken tension pin that retains the bevel gear to the crank.
Look for and carefully remove snap rings to disassemble unit.
Mine was a one piece cast iron housing and cannot be sealed if they ever wanted it serviced.
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
Pallet of Vehicle Seats (A54816)
Pallet of Vehicle...
12' CONTAINER (A52706)
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
