Three point lift problem
/ Three point lift problem #1
jaroban
TX
Kioti dk40se
I have posted a few times in the past few days about a 3 pt hydraulic problem. In summery I had a 3 pt that would not work properly. The o ring and Teflon washer were blown out . I changed the o ring ( part #15 63x5.7 and the Teflon washers . part # 19 a63x2). I took the piston and cylinder to the local seals place In Fort worth and the dimensions of the 0ring should have been 52.3x5.7. So I replaced the o ring and the two Teflon washers. The three point lift worked perfect for three operating hours. Now I am using a two row five foot disk and it will not even stay up long enough to make a corner. It will fall almost immediately once I let off the lift lever. Can you inform me what might be the problem? Thanks Robby http://www.johnstractor.homestead.co...dPowerLift.jpg
/ Three point lift problem #2
On these 200 series Jinmas, a very common reason for O-ring and wiper damage is trying to lift an implement too high. Doing so can cause hydraulic piston travel to exceed cylinder length. The O-ring and wiper are pushed outside the cylinder wall, then torn/damaged when pulled back inside. This can happen when the adjustable stops (wingnuts and springs) for the lift lever aren't set properly - or aren't used at all. When these stops are properly positioned, piston travel stops before the O-ring and wiper get pushed out of the cylinder.
//greg//
/ Three point lift problem #3
Greg is on target. To clarify a little, you will see a rod that is attached near the base of the raise lower lever and runs through a block attached to the lift arm. at the end of this rod are a pair of jam nuts. loosen them and run them a little further up toward the front of the tractor then retighten (jam) them. I don't have a jinma parts book at this desk, but it should list the correct size O ring. Since you didnt use an OEM seal kit, it is possible the fit of the o ring was not the same as the original, but I think you'll find the adjustment was the culprit. Sorry one of us didn't get that info to you sooner. not a bad job, but not fun to do it twice in a few hours!
/ Three point lift problem #4
Thanks Chip, been a long time since I got rid of those Jinmas. I remember that stop bolt on the linkage rod now. But it's too late to edit out that wingnut and spring mistake above.
//greg//
The original o ring in the book is 10 mm to large it will not even fit in the cilinder. I will replace in the morning . I will also move the jam nuts so that it will not raise so high. I will post in the morning and keep you updated . Thanks for the advice, Robby
The problem is solved . I moved the jam nut so that i would not be able to lift so high then I cut off the extre on the rod so this problem would not happen again. Thanks for the help Robby
/ Three point lift problem #7
I never thought about cutting a little off that rod, as a dealer. I will do that on any Jinma 200 sereis that cross my lot from now on!
2020 CATERPILLAR 316FL EXCAVTOR (A65053)
2020 CATERPILLAR...
2022 Chevrolet Silverado 6500HD 4x4 Service Truck (A64194)
2022 Chevrolet...
2012 Ford Expedition SUV (A64557)
2012 Ford...
2018 International DuraStar 4300 26ft. Box Truck (A61573)
2018 International...
2003 Gradall XL3100 Highway Speed Wheeled Excavator (A64553)
2003 Gradall...
2022 EZ-GO ELITE...
