Three point hitch
/ Three point hitch #1
Okstate
Kioti CK20S HST
I have a Kioti CK20S HST that was given to me. The three point hitch doesn't work. The Hi-Lo lever was broken also. That has been replaced but it still won't shift. Could that be causing the three point not to work?
/ Three point hitch #2
So - the 3 point hitch not going up or Down ?
/ Three point hitch #4
Also if the 3pt speed adjuster is closed off the 3pt will go up but not down. If it’s similar to my CK30HST the adjuster knob is under your left knee beside the 4x4 knob but above the diff lock lever… turn it to the rabbit setting and see if that makes a difference.
/ Three point hitch
the three point hitch won't go up or down. I have adjusted the speed knob all the way to rabbit and still no operation. I asked at the Kioti dealer and they mentioned something about a solenoid. I may be thinking wrong, but I didn't see any solenoid or a connector either. Not sure if it has a remote lever.
/ Three point hitch #6
Something you can try is to raise and slam the three point arms down a couple of times.
I bought a new tractor last year and the three point quit working. The dealer said to raise and drop the arms. That did not work. The young technician came out and raised and SLAMMED the arms down. It woke the system up. Something about debris obscuring the valve.
I hope the fix is something as simple as this.
/ Three point hitch
I tried slamming the arms, to no avail. I may not have slammed them hard enough. The Kioti dealer mentioned a solenoid for the three point. I have found no evidence of one. Is there a solenoid in that mechanism?
/ Three point hitch #8
I found the following information for your tractor:
If the three point arms cannot be raised by setting the hydraulic
control lever to the "UP" position after long term storage or when
changing the transmission oil, follow these air bleeding procedures.
1. Stop the engine.
2. Set the hydraulic control lever
to the "DOWN" position and
start the engine.
3. Operate the engine at low idle
speed for at least 30 seconds
to bleed air from the system.
I hope this helps.
/ Three point hitch #9
Have you connected anything to your Rear Aux to see if it works?
If it is not working, you are not getting anything from your power beyond off your joystick controller.
/ Three point hitch
No rear aux. The dealer at OKC told me to clean the MLS valve. How do you remove that valve without something flying off somewhere?
/ Three point hitch
Finally got the valve out, any suggestions on proper cleaning?
/ Three point hitch #12
Any chance of some Pic's ? most of us have neaver seen one removed !
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A65054)
(INOP) 2013 MACK...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A68842)
GENERAC MOBILE...
2437 (A65640)
2437 (A65640)
CAT J600/375L Teeth (8) (A68134)
CAT J600/375L...
2008 FORD E-350 CARGO VAN (A66091)
2008 FORD E-350...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
