three point hitch will not operate
/ three point hitch will not operate #1
cblowers
Three Rivers, Michigan
2012 Mahindra 5010 gear drive
Bought 2012 5010 Mahindra at an auction. Figured it would have problems with it but the price was right. The problem is that the 3 point hitch does not operate. The hydraulics won't raise or lower with the levers. You can move them manually. It has power steering and the PTO works. Removed hydraulic pump, had it tested which was fine. Have been told that the problem may be in the orbital (proportioning valve may be at fault). Would like to know if there is a test procedure to determine if that is the problem. Thank you in advance for your replies, suggestions or help.
2022 EZ-GO ELITE...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2025 SDLanch SDLL60 Mini Stand-On Track Loader Skid Steer (A64553)
2025 SDLanch...
2005 20 Ft. Grady-White Boat with 25 Ft. Float-On T/A Boat Trailer (A64557)
2005 20 Ft...
2007 International CE200 School Bus (A64194)
2007 International...
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
