Three point hitch lifting problem
   / Three point hitch lifting problem #1
hoot1293
I have a MF 65 diesel tractor that the lift on the back is going up real slow. After it runs for awhile it goes up quicker but not as it should. Any help would be appreciated.
   / Three point hitch lifting problem #2
Have you checked the hydraulic fluid level. If low it could cause the 3 pt to rise slow. Also could need a fluid / filter change.
   / Three point hitch lifting problem #3
Fluid level ok? Is the fluid dirty?
Air in the system?
The fluid is clean and at proper level. Is it hard to change the filter.
   / Three point hitch lifting problem #5
When a filter is hard to access, it usually does not get serviced as it should. May be worth checking into? Ken Sweet
   / Three point hitch lifting problem #6
There may be an inlet screen on the hydraulic pump pickup that is restricted by sludge/debris.
Thanks for the help. I will try these solution
   / Three point hitch lifting problem #8
I had a 135 for many years and have just about completely rebuilt it. If you check out the MF site you should find some of my posts with pictures. A 65 is not that much difference, check it out. After replacing seals, cleaning filter, and adjusting top link spring the 3 pt lift arms had lots of power and was smooth. Like new. Great tractor, I wish I still had it.
   / Three point hitch lifting problem #9
If you can't find the info you are looking for I will post a few pictures for you. I might be able to help.
Please post pictures
2008 Nissan Sentra Sedan (A51694)
2008 Nissan Sentra...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53472)
2023 NEW HOLLAND...
JOHN DEERE Z530M LOT NUMBER 173 (A53084)
JOHN DEERE Z530M...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
