JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 4,022
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
Nope. Disagree. This is OK as I think we both understand how the system operates. I won't belabor our permanent disagreement beyond this post.Sorry, but I think you are confusing draft as a nautical term with draft as a farming term. Draft, as a farming term is the horizontal force required to pull an implement through the soil.
The draft on a 3PH is controlled by raising and lowering the implement by the draft control feature as the implement encounters variation is soil. The position control on a 3PH simply establishes a baseline depth.
Draft (hull) - Wikipedia
en.wikipedia.org
Agricultural Machinery Management (ACIS)
This is a document on , one of a series of documents on cotton crop management. Provided by the University of Arizona.cals.arizona.edu
My MF2660 Operators Manual, pp. 5-21, says, quote, "Draft Control is used to control the working depth of soil-engaging implements." The sensing is all vertical axis. The feedback control loop adjusts lift only in the vertical axis. Any horizontal forces are secondary to the feature, not the goal, and are not controlled by it.
