Three point control question...
   / Three point control question... #1
HuckBB62
Posey, CA
Yanmar F18D
On my F18D, it has two levers by my right hip. I know that they control the BB's up and down but in the manual, one is listed as the position control, the other as the draft control. How can I use these properly?
   / Three point control question... #2
The position control is all you can use. The draft control is for the tiller and must have all the linkage that comes with it to make it fuction. That is usually left in a pile somewhere between Japan and here. If it is an electically controlled draft, you might get it to function. I have only had one tractor that came with all the linkage and electrical sensors to make it work.
Thanks for the info, by the way, of the two levers, is the right one or the left one the normal position control? Both will move the hitch.
   / Three point control question... #4
You got me there. On all the tractors I have delt with only one would actually move anything. It is usually the outer lever though.
2020 JOHN DEERE 7R210 LOT IDENTIFIER 253 (A53084)
2020 JOHN DEERE...
Deere 9970 Cotton Picker (A53472)
Deere 9970 Cotton...
(1) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(1) UNUSED 7000#...
2009 DRAGON  130BBL VACUUM TRAILER (A53843)
2009 DRAGON...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
90018 (A48082)
90018 (A48082)
