three point arms dont raise
   / three point arms dont raise #1
bighead51
Royse City Texas
JD,IH
A friend has a JD 4wheel drive tractor dont know the model # but its about 90 95 hp . the problem is the three point doesnt work all remotes work everything else is ok it but the lift arms wont raise up they stay in the down position . I get in touch with him get the model # and year . I know this isnt much to go on but maybe someone might know something? thanks Ok Its a JD6410 I think its a 2004 year model hope this helps
   / three point arms dont raise #2
The model will make a huge difference. Some are electronically controlled and might have wiring or fuse problems. Some have mechanical linkage and could be disconnected, broken, or misadjusted linkage. Either one could have hydraulic valve problems. Post back with model and symptoms leading up to failure. (was it intermittent at first or sudden failure ...)
   / three point arms dont raise #3
Also they have a float control knob down below the seat....rotates left and right to control the speed of the 3 point. if this knob gets turned too far in one direction, the 3 point will not lift. check this knob out
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
2012 Ford F-350 Omaha Service Truck (A51692)
2012 Ford F-350...
2004 Wabash National 28ft Dry Van Trailer (A51692)
2004 Wabash...
John Deere PT Land Leveler (A50123)
John Deere PT Land...
