Three Phase Power and Welding
/ Three Phase Power and Welding #21
Hmmm, you're correct, but I'm sure the coop told me 26 kw. I'm wondering now if that was a coop imposed limit? They also told me $48k to string wire down the road for 3 phase several years ago.
Here in Conn we have plenty of 200,400,600 & even a few 800Amp 240V single phase services.
Andy
Utility Engineer
/ Three Phase Power and Welding #22
A phase converter, rotary or otherwise won't be able to output any more power (watts) than you put into it. Add in conversion losses & you'll be worse off.
Not clear if you are talking about a welder or something else. I couldn't speak to the value on the conversion making a welder any smoother as I'm not much of a welder & never used a 3 phase machine.
Are you currently running a 3 phase machine off single phase? That's the only scenario that could benefit besides the smooth output thing. Or having a 3 phase only machine around that you can't use without 3 phase.
/ Three Phase Power and Welding #24
I have a High end Tig welder that will put out 300 amps on 3ph but it only does 200A on 1ph. I have a Mig unit that is the same. 400A on 3ph / 320A on 1ph. Not that I need the power on Mig but Tig welding it could sometimes help on thicker Aluminum. I was just curious if the converters were worth messing with.
/ Three Phase Power and Welding #25
The only advantage there would be smoothness or what not. With 3 phase you are splitting up the power across multiple cables rather than just 1 (ignoring the neutral part of the equation). That means you can get more wattage across smaller cables, although you have more of them. It's easier & more efficient at higher wattage to run 3 phase with smaller wires. But converting from single to 3 phase means you'll need a beefier wiring & a phase converter. You won't gain any watts on the input side of the equation. The machine could handle more watts though.
/ Three Phase Power and Welding #26
Yomax, if you really needed it, you could get an oversize converter, run it on a very large single phase circuit, and be able to generate the full power from your welder, I believe. I would bet that would do the trick, but it would be very costly to do so. I'm also not sure how the generated phase being different than line 3 phase would affect the welder, if at all.
/ Three Phase Power and Welding #27
Or just give the welder to a needy, good looking but somewhat neurotic Canadian farmer who has 3 phase power.
/ Three Phase Power and Welding #28
I'll send you a few. Border open on July 21st? I think.
/ Three Phase Power and Welding #29
Good Info on the Phase Converter. Thanks Much !
I知 not certain
I am thinking about just buying a 3 phase generator as they are less costly to buy than single phase generators, then just split the power at a loadbox. The extra cost of the loadbox will mean the cost is ultimately the same for 3 phase as single phase, but enable me to have both at my house. That way I can buy welders/machine tools with 3 phase motors, but also have backup power for my house if I need it.
A 30 KW 3 phase generator is only $1800.
I was hoping the guy who has Everlast Welders would chime in, only because I like Inverter Pulse Welders and wondered since pulse has AC Secondary Voltage, if three phase power as background amperage would make a difference on weld quality in that application? I would think it would be a lot smoother, and maybe give you more pulses per second.
I was reading this week that some pulse welders are approaching 400,000 pulses per second now. I would think AC background amps would be the only way to get that???? Crazy for sure.
/ Three Phase Power and Welding #32
Anyone run a phase converter? I have some equipment that would have a lot more output on 3ph. Not sure if it's worth it.
I see a lot of welding equipment for cheap but all 3 phase. If a converter is $100 that would justify buying. I just saw 3 Miller machines with wire feeders and controllers for 500or 600 bucks on craigslist. But I have not idea how to hook up a phase converter nor where to buy one.
/ Three Phase Power and Welding #33
I see a lot of welding equipment for cheap but all 3 phase. If a converter is $100 that would justify buying. I just saw 3 Miller machines with wire feeders and controllers for 1000 bucks on craigslist. But I have not idea how to hook up a phase converter nor where to buy one.
Miller Welders - tools - by owner - sale
/ Three Phase Power and Welding #34
I have always heard this, but I am trying to figure out why it would be that way.
It would like be drinking from (3) smaller straws, rather than one bigger copper pipe, but how would that be smoother? A person is still getting enough milk from the bowl. And so it would be with welding, a person is still getting enough electricity to maintain an arc, it is just coming from (3) wires instead of (1).
I could see if a person was welding with AC in the rare instances that is used, but we mostly use DC power, and so there is no frequency to contend with (unless using pulse welding). The only places I could see where it might be smoother is where AC is used...
AC Stick Welding
AC Aluminum Tig
AC Cast Iron
Pulse with AC Secondary Background
/ Three Phase Power and Welding #36
Some Millers can be converted from 3-ph to 1-ph using a model-specific Haas-Kamp conversion. This Spring we converted two CP200s and a CP300. The 200s required two caps ea, and the 300 needed four to go 'by the book'. (Each capacitor uses a bleeder resistor vs store a potentially dangerous charge when shut down.) <$50 to buy the bits for each, and Pat's employer was giving away old Millers.
If you get on the Haas-Kamp conversion sites and threads you should find the detailed instructions. Cheap as we are we're welding a lot here with 100% CO2 using beverage svc bottles and the thread adapters for such that come with some gas valves.
Rotocons need the legs balanced for load. Static converters are the pits w/o an idler motor added. Running extra motors/machines no-load can be a way to smooth out the phases. YMMV
Phase Perfect (TM) is best if pricey, costs way less than adding three phase service, and doesn't need tweaked for load like a RPC. Several $K to play.
Here's a video of a guy converting a CP200 pretty much the way we did our two side by side. YouTube
/ Three Phase Power and Welding #37
Here's a couple videos that should help explain 3 phase
YouTube
YouTube
One thing to remember - just because you add a diode in an AC circuit, this does NOT mean you will get DC that is a constant voltage (like a battery) - the vids sort of cover this. They're a bit "wordy" in spots, but if you watch BOTH all the way through, it should clarify some of the misconceptions I've seen on this thread. If I were to "improve" on them it'd take a LOT more time than I have at the moment; (Life is the crap that happens to ya while you're busy makin' plans :rolleyes: ) ...Steve
/ Three Phase Power and Welding #38
I added these caps good for the 600 Volt line, to try and correct the manufactured phase that the Lincoln Computer did not like. It helped, but the Math changes when the load changes.
Having to start and stop a Rotocon, everytime you want to weld was a giant PITA! And my 10 HP unit drew something like 500 amps or more inrush current!
Cub cadet LTX1045 Lawn Mower (A63116)
Cub cadet LTX1045...
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
TAKEUCHI-VIRNIG TRRG72 - 72" HYD ROOT RAKE GRAPPLE (A62129)
TAKEUCHI-VIRNIG...
CRAFTSMAN 20 GALLON ELECT. AIR COMRPRESSOR (A62131)
CRAFTSMAN 20...
Pallet of Forks (A61567)
Pallet of Forks...
