Thread pitch for front axle grease zerk?
/ Thread pitch for front axle grease zerk? #1
C4Ranch
Veteran Member
Eastland Co, Texas
Kubota L5240 HSTC
I poped my grease zerk and need to replace, anyone know the pitch? It's not M10
/ Thread pitch for front axle grease zerk? #2
Could it be a drive in zerk they are so small it's hard to tell weather or not it has threads if it just popped out and didn't break off it probably is drive in fitting
It's threaded. I bought an assortment pack of metric fittings but the m10 didn't fit.
/ Thread pitch for front axle grease zerk? #4
In this thread I discovered my loader uses 1/4-28 zerk. So I would guess yours is SAE thread, not metric.
/ Thread pitch for front axle grease zerk? #5
Grease fittings are normally found in two sizes,a smaller one and a larger one.
On domestic built equipment,the smaller one is 1/4-28,the larger one is 1/8 NPT(National Pipe Taper).
Metric equivalents would be 6MM X 1.0 for the small one,with the larger one is 1/8"BSP(British Pipe Taper).
Since the loader is USA built,it would have the former fittings.
While the tractor itself is Japanese,it would use the latter fittings.
Therer is a 10mm straight fitting available,which is most likely what you have that doesn't fit.
If that's the front axle pivot fitting we're talking about,I believe it would be the 1/8" BSP
IIRC the 1/8 NPT is 27 threads per inch and 1/8 BSP is 28 threads per inch.
The O.D. of an 1/8" pipe thread fitting would be close to 10mm.
Pipe thread is measured by the I.D. of the pipe.
Sorry to ramble but hope this helps.
Good Luck!
Thanks, yes it does help... :mur:
2015 Globe Traile GTDD30236 75yd. T/A End Dump Trailer (A61568)
2015 Globe Traile...
2019 WABASH DVLSHPC 53X102 T/A DRY VAN TRAILER (A59906)
2019 WABASH...
24220 (A56859)
24220 (A56859)
2015 BOBCAT T770 SKID STEER (A62129)
2015 BOBCAT T770...
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
