Thoughts RE Bad Boy Renegade Diesel vs. Kubota ZD1200 ZT Mowers
   / Thoughts RE Bad Boy Renegade Diesel vs. Kubota ZD1200 ZT Mowers #11
Having the ability to test-drive options for your specific situation is best…especially when you have hills and rough terrain.
I tried several ZTR’s on my property (including a BB) and was sold on the Cub Cadet with the steering wheel after a demo.
Mike
Thank you!
Will continue to consider. Need to find out what is available in my area.
   / Thoughts RE Bad Boy Renegade Diesel vs. Kubota ZD1200 ZT Mowers #13
Good luck. For what it’s worth, I’ve had a Bad Boy Outlaw (gas) since 2015 and it’s been terrific.
But - my mowing areas are pretty flat and gradual elevation changes. The worst I have is about 20 degrees and the Bad Boy handles that just fine - even if the grass is a little damp.
MoKelly
   / Thoughts RE Bad Boy Renegade Diesel vs. Kubota ZD1200 ZT Mowers #14
ZTs can handle steep slopes IF you are an experienced operator. However, some skid marks can happen
   / Thoughts RE Bad Boy Renegade Diesel vs. Kubota ZD1200 ZT Mowers #15
Agreed.
My Cub Cadet Pro Z 560 S is designed for around 20 degree slopes, I believe but, I mow on some 40 + degree hills.
On the steep stuff I mow mostly straight up and down but, there are trees I mow around and I don’t have a plateau up top, so I have to also change direction in steep areas all the time.
I personally wasn’t able to operate a lap bar setup without sliding down my hills but, with the steering wheel, I’ve been able to do it all.
Maneuvering the steep stuff takes some getting used to but I’m amazed at what this Cub Cadet has been able to do.
Mike
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
New Bulk Lot Chain Slings (A53002)
New Bulk Lot Chain...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
AMADAS SPC-6 LOT NUMBER 257 (A53084)
AMADAS SPC-6 LOT...
2014 Dodge Avenger SE Sedan (A51694)
2014 Dodge Avenger...
