Thoughts on new echo trimmers
   / Thoughts on new echo trimmers #1
DeNiro
Raleigh, NC
Kioti KL3054 / Iseki TL2100
After reading many posts here praising the quality of Echo string trimmers I decided to buy a new one and now I am reading that the new models have to meet new EPA requirements and may not be as good as the older ones(last year models). I have read elsewhere that they don't have the power or run as clean as the older unts.
Some of the older models are still available and I can get a fairly good deal on a few. This place is pretty full of knoledgable folks and I wonder what the thoughs and feelings of some of you guys might be??
   / Thoughts on new echo trimmers #2
If you feel it is underpowered go to Lawnsite.com or arboristsite.com and look up "muffler mods" and you can find ways to get a little bit more power out of it. My dad had an old Echo that seemed well powered, he just got a new Echo this year and I have only run it once. I didn't like it but it seemed to have the same power as his old one, reason I didn't like it is because my Stihl FS 96 is more powerful, has bike grip handles to it and was only 50' away. So needless to say I went and picked mine up and put his back in the truck. I guess doing this stuff commercially I may have got spoiled on my Stihl and didn't want to go back to the standard grips. But all in all it seemed to have plenty of power.
   / Thoughts on new echo trimmers #3
I did commercial mowing for a few years and have owned a couple of Echo string trimmers. Echo makes good trimmers. Stihl trimmers are much better for me. The FS80 is the best they make.
   / Thoughts on new echo trimmers #4
I own a Echo and think it's a good trimmer, but, Man Lube the Cable, Lube the Cable. I didn't know you had to do this and was losing power big time. I took the cable drive apart a grease everything up and it was like new again. bjr
I guess you guys did not get the idea behind my question. I an pretty sold on the Echo trimmers, but the question was wheather the new models that have to meet the EPA requirements would be as good as the old ones.
I found a good dealer and he satisfied most of my questions and I bought one yesterday. I used it about an hour and I have no doubts that I chose the right size unit. I use it a lot on a hill side and the light weight unit is a breeze, even when I am falling down the hill.
I was pleasantly surprised that the service was so good and the price was right. The unit was completely assembled and filled with gas and I got a short course in use and maintenaince. Get this, $10 cheaper than the big box store and they filed my 5 year warranty on line before I left.
   / Thoughts on new echo trimmers #6
Make sure to use quality oil and 91 plus octane fuel and you should be fine.I own a newer echo chain saw and back pack blower and have had ZERO problems.coobie
   / Thoughts on new echo trimmers #7
all they have is a catyletic converter (spelling?) in the muffler, and screws that limit how rich you can run the carb. So, you take a drill out the muffler, and let it breath, and then remove the limiter screws on the carb and adjust it propperly, and its a whole new animal. NOT EPA approved! ;)
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A52377)
2021 Freightliner...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2022 CATERPILLAR 303.5 CR EXCAVATOR (A52705)
2022 CATERPILLAR...
