Thoughts on Cold Starting...
   / Thoughts on Cold Starting... #1
rmonio
Platinum Member
New Market, MN
JD 4600, JD B
   / Thoughts on Cold Starting... #2
In the old days we got gasoline tractors which handled the cold better. We used lots of ether. we got a 5 gallon bucket of hot water, set it under the oil pan & put a tarp over the hood to make a mini tent & waited 30 minutes. We pulled the gas tractors if we got any one started. We drained the oil every time we parked it, & put warm oil in every time we wanted to start it. For a diesel you can light a fire with a rag or a propane torch & direct the heat into the aircleaner & crank the engine over - this is dangerous but you asked what farmers did/do.
As a fellow Minnesotian with 6 tractors & 5-6 other motor machines, I make sure the machine runs every 4 weeks or the battery is stored in the basement or a charger is put on the battery every 3-4 weeks. I keep the machines in unheated sheds (a month ago when it hit 0 outside, my bigger diesel started right up the next day on summer fuel & summer oil - the shed kept the tractor about 30 degrees for that extra day or two). I try to plug them in, water heater only, when it is below 20 degrees.
Best prep is to change the fuel filter in fall; use a winter grade of oil; use #1 diesel blended 50/50 with #2 plus a bit of fuel additive for cold weather; change the fuel filter in fall; keep the tractor in a shed that will add 5-10 degrees even without heat; have a way to heat it up, electric plug in or a torpedo heater (see the shed helps); make sure your battery & electrical system is in good shape & charge it if your tractor sets more than 7 days in the cold; and change the fuel filter in fall.
In emergency, use a bucket of hot water, direct a hair drier into the air intake, etc. You often only are 5-10 degrees away from getting the starter to spin fast enough (cold oil drag) and adding 100 degrees of heat to the air intake will make a WORLD of difference on the ignition.
Ether is really bad for diesel engines, and can wreck the manifold (explosive shrapnel) with many preheaters but ifyour tractor allows it & you know the issues it can be a neccesary evil for cold starts.
--->Paul
Thanks for the feedback, Paul. Fortunately I'm blessed with a poleshed, heaters, and the ability to plug it in before-hand. But I've always wondered what Farmers did years ago - thanks for sharing. We do have it pretty easy these days.
-Bob
1995 Well-Craft 210 SS Elcipse Boat (A50515)
1995 Well-Craft...
Excavator Mulching Head (A50774)
Excavator Mulching...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A52577)
2016 WESTERN STAR...
2019 Freightliner Sprinter 1500 Van (A50323)
2019 Freightliner...
2014 Chevrolet Equinox SUV (A50324)
2014 Chevrolet...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
