Thoughts on a log splitter like this
   / Thoughts on a log splitter like this #2
That splitter will only work on perfectly sized logs. If you have to do multiple splits, you'll waste all your time dinkin' around with the loader while trying to pick up the round correctly for the split. Multiple splits are a piece of cake with regular log splitter or 3PH splitter. I position my splitter over my trailer or the bed of my Kawasaki Mule so that when the first split is made, I can then pick up and reposition the round for the second split. I just think efficient splitting takes too much hand work for this splitter to be anything but a novelty. ...my $0.02 worth.:)
Thank you for the reply.
I was thinking about making something like this if others thought it was a good idea.
   / Thoughts on a log splitter like this #4
Splittail log splitter on youtube is about the same thing, I think, but for a skidsteer. It seems to work on the youtube video.
   / Thoughts on a log splitter like this #5
I'm sure it has it's place- depending on what you need to do. I would tend to think it is a unitasker and I would still need other options. BUT I do like the idea of pick it up and split...someones "million dollar idea" at work.
I wonder if you would be able to put a star wedge on it to deal with the multiple split scenario? If you were going to make your own, then you certainly could customize it's abilities to suit your needs. Might be worth a try.
   / Thoughts on a log splitter like this #6
It looks like it wouldn't be cheap to buy since it uses a PTO powered pump. If you had the parts it might be worth trying but I just use the front bucket to roll large logs into then posistion it over the splitter and roll them onto the beam. That way I can just split a portion of a large log and push the rest back into the bucket while I further split the chuck I just took off.
I'm not sure splitting over a truck bed is all that great of an idea. I like to stack it so I can get the most in the bed and if there's too many random logs in the bed it makes for a difficult time moving them out of the way so I can start a row.
Now it would be nice to just drive around and slit the larger logs where they lay so nothing was big but that would make it a second splitter when really only one is needed.
   / Thoughts on a log splitter like this #7
Doesn't look very exciting to me. Showing it over the pickup bed is the least likely way to use it, IMO. Tying up the tractor for the splitter is another negative. For me, the tractor is an important aid to moving large logs to the independent splitter, and moving split firewood on pallets away from the splitter.
But it may be just the cats pajamas for certain people. I'd not be one of them. :)
   / Thoughts on a log splitter like this #8
We use a home made set up like this on a 743 Bobcat. The quick hitch plate allows fast changes to a bucket when loading into a 1996 Ford 1 ton dump truck. All splitting is done on the ground. The idea of splitting wood over the back of a newer truck bed brings a smile. The splitter uses the aux. hyd. on the Bobcat. Does have a "fun" factor.
   / Thoughts on a log splitter like this #9
I have a serious problem with that thing. First its going to take you longer to split with having to move around all the time. Also your asking to hit the side of your nice new truck if you split in to the truck.
I notice all of these log splitter videos they are cracking nice clear wood. I can out split a log splitter by hand if i am working with clear wood. Most of the time when i am cutting my by my self i split the clear by hand the knotty stuff i save for the splitter. Saves alot of gas on the tractor that way as well and its one **** of a work out.
   / Thoughts on a log splitter like this #10
The last video of them picking up the large log ...wonder if the FEL arms could get tweaked with all the weight on one side, especially if carrying the log and hitting a large bump. I'd prefer the weight to be centered.
I suppose if one had physical limitations on man handling the wood it could be useful though..
2018 BIG TEX 35+5 T/A GOOSENECK (A50854)
2018 BIG TEX 35+5...
Set of Ag R4 Wheels and Tires (A51039)
Set of Ag R4...
2004 INTERNATIONAL 4300 CARGO TRUCK (A50854)
2004 INTERNATIONAL...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2009 UTILITY TRAILER MFG. CO. SEMI TRAILER 57 (A50854)
2009 UTILITY...
2009 Ford F-250 Pickup Truck, VIN # 1FTSX21Y49EA41686 (A48836)
2009 Ford F-250...
