Thoughts on a 2019 LS XR3135H- only 45 hrs??
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #11
To echo what others have said already, ask if the 50hr service has been done. It probably hasn't, but will need it very soon. The 50hr service is simple enough, just follow the manual.
To compare it with the Massy 1735M is like comparing a blue golf ball to a red golf ball. They are practically the same tractor, with different engines, and either will likely serve you well. Look at the features of each and get the tractor that you like the best, with the features you will use the most.
But that LS... That a pretty great find, if there is nothing wrong with it. Check with the dealer.
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #12
I never thought I'd hear myself saying this but I think I would go with the LS over the Massey in this case. We have a Massey 1750m and there is a thread or two right now about how the massey seems to be dealing with some power loss issues when bushhogging for an hour or so.
I have an LS R4041 (Badged as a Case IH Farmall 40B) Shuttle Shift and it is a mowing beast. For bushhogging/mowing, I prefer it over the Massey which is a hydrostat.
My personal opinion is that you're looking at too small a tractor for 20 acres of mowing but it can be done. You will just get some good seat time. Buy something that has at least 30 PTO HP and you can put at least a six foot cutter or RFM on it.
If I were buying a tractor to primarily mow 20 acres, I would be looking at a Shuttle Shift, not a Hydrostat.
As far as it only having 45 hours, not hard to believe it at all. Guys buy tractors all the time and use them very little and then sell them. Just do the 50hr service as was mentioned.
Edit: I see now that the LS has 30pto hp, so though probably still a tad small, at least you can run a 6' bushhog or a probably a 7' RFM.
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #13
Ok I am your missing voice. I have XR-3135 C 2019 model. This tractor has been reliable without issue. My unit was ordered with backhoe. I have ran 7 ft disc mower Lely without issue with it. The turbo makes the 35 hp seem like 55 hp. I have 175 hours primary use is backhoe work. No issues with tractor I buy another if needed. Good value with strong drivetrain. I will tell you to use cab fresh if buying cab tractor. Critters don’t like the smell. I also use peppermint oil they don’t like that either.
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #14
About the only things I'd be asking are, "Will you take a check?", and "Will you deliver?"
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #15
Hello- Looking to replace my Dads 40 yr old Kubota L235 to mow about 20ish acres of field in NH- I am going to buy used as we only use it a few times a year ( It is a summer place)- I am looking at a Massey 1735M and just saw the LS XR3135H go up for sale- It comes with Third function valve,Worksaver 48" Grapple, Quick Attach and Forks- I can get it for around $20K- Any issues with this model??- both have the loader-which do you think is the better tractor for same $$$$-- thks so much-
Will 30HP at the PTO be enough?
Why do we think that 30 at the PTO will not be enough = My dads L235 only has 19.6 and that is enough to cover his 5 foot brush hog??- thks
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #17
It was just an observation and question, no offense intended...
None taken- I am a novice so I am sorry if it came across wrong- I was seriously asking why people feel I may need more- Just want to get the right tractor-
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #19
Everyone will always tell you to get more and bigger. My 35HP does everything I need. Just a tick short of reach on a double stacked hay trailer, have to finesse the center stacked round bales to the edge. I can always push them off with another bale if needed.
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #20
Because these days 200hp isn't enough for a grocery-getter so now you need 10hp/ft for mowing.
(nb sarcasm)
1652 (A58375)
1652 (A58375)
1988 Mack R690ST Day Cab Truck, VIN # 1M2N277Y9JW007124 (A57453)
1988 Mack R690ST...
Hydraulic Floor Jack (A59076)
Hydraulic Floor...
TRUCK MOUNT TOOL BOX W/ SAFETY WORK SIGNS (A52708)
TRUCK MOUNT TOOL...
2317 (A58376)
2317 (A58376)
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
