Thoughts on a 2019 LS XR3135H- only 45 hrs??
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #1
bebop86
NJ
Hello- Looking to replace my Dads 40 yr old Kubota L235 to mow about 20ish acres of field in NH- I am going to buy used as we only use it a few times a year ( It is a summer place)- I am looking at a Massey 1735M and just saw the LS XR3135H go up for sale- It comes with Third function valve,Worksaver 48" Grapple, Quick Attach and Forks- I can get it for around $20K- Any issues with this model??- both have the loader-which do you think is the better tractor for same $$$$-- thks so much-
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #2
I don't have any experience with either tractor, however, there is a thread here on TBN discussing extremely frequent regens on at least one LS model. I think it's like every 2-3 hours, which is insane.
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #3
That is the 30-40 series with interim tier 4. The 31-41 series have a different motor and seems to be right at 50 hours most of the time. 650 hours on my XG3135H stripped down model from the XR models.
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #4
That's me!
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #5
Id be concerned about a tractor that old with such low hours. Its been sitting, and machinery does not like to sit for long periods. Also, the big question in my mind, WHY was it sitting? Is it someone's lemon they are trying to off load?
As far as issues go, none really. I mean, you'll hear of people having one off problems with wheel bearings on the front axle, ECU problems with wire harness, etc. The most common problem is the ground connection. If you buy this LS, take the battery ground off the frame, grind down the paint, clean it, and put it back on tight with thread locker. Other than that these tractors are solid!
For $20k and low hours (assuming it's not a lemon) with all the extras, thats golden! Mowing 20 acres might be a challenge... well, if you've been doing it with a Kubota L235, then using the approximate same size LS wouldn't be any different. I'd step up in size, but thats me.
Let us know what you end up doing! And pictures.
Here are some pics of the unit-
So I spoke with the seller- He said he bought it to clear paths on his property- It was great for the wood chipper but way to big for normal use on the property- Of course he said he has had zero issues with the machine??- thks for all your input- Is there any specific questions I should be asking him??
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #8
looks nice, clean, has dual rear remotes and 3rd function, hydrostat, suspension seat, etc. (looks brand new in those pics)
I'd ask what dealer he uses (or just call the closest LS dealer) and see if they have a maintenance record on the tractor for major issues/repairs etc. Should be able to get the SN from the back tag when you view the tractor.
I'd ask to dive it around his property a bit, see how it feels, sounds and acts.
Check under the hood, look at the bolts holding it together, is there damage on them showing it's been split apart? Check the oil and hydraulic filters, have they been changed, or are they still painted on from the factory, etc.
Certainly looks good in the pics, maybe you found a good deal.
Thks so much- will call dealer on Monday-- How would you compare this to the Massey 1735M which I am also looking at used- The ones I found seem to have alot more hrs but still low- Under 300
   / Thoughts on a 2019 LS XR3135H- only 45 hrs?? #10
Ask if any service has been done yet such as fluids and filters. If not it is due. Seems like very low hours, 45 hours in 5 yrs. is super low. I have the older 3000 series cab model and I put under 40 hours per year on it. Mine is 10 years old now.
LS3135 has an LS engine, Massey 1735M has the Shibaura engine (same as mine). I have not heard of any (or very few) problems with either. The under 300 hr. Massey is still like new too if around the same year. I'd have no problem with either if I were looking (other than no cab). I like heat and A/C depending on the season.
1704 (A58375)
1704 (A58375)
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
IRanch Mini Excavator Auger (A57149)
IRanch Mini...
JLG SCISSORLIFT (A52705)
JLG SCISSORLIFT...
Hose Reel (A55787)
Hose Reel (A55787)
