Those with a 2360 SnowBlower
   / Those with a 2360 SnowBlower #1
DEWFPO
"Up High in the Rockies"
2009 Bobcat Toolcat 5600 D
I'd like to ask a favor of those with the 2360 snowblower. I would like them to measure the distance between the front leading edges of the sides of the horizontal auger case at about the same height above the ground as the auger shaft itself.
I abuse mine every winter and the sides of the auger box are looking more and more splayed outwards to me. I just wanted to check the measurements against others in case I need to adjust mine inwards a little.
Thanks in advance.
DEWFPO
   / Those with a 2360 SnowBlower #2
Damm :mad: I've used my 2360 blower for the third time this week and everytime I go outside I have full intention to look and see if the front is splayed out. This morning I'm looking at it again and it does look wider in front. Of course no tape measure handy. I will measure it when I get home from work this morning. (third Shifter).:eek: If I can remember to.
   / Those with a 2360 SnowBlower #3
Okay i'm home now. If you measure across the outside in line with the auger it's 50 and 3/8" in you go inside where that little detent that is slightly wider ends I have 49 and 1/2". How's that:D
Thanks BobZap, That's exactly what mine is as well, in both locations so I guess it's just a visual thing that makes it look splayed out. I occasionally catch the edges on stationary objects sticking out of the ground and was wondering whether I bent them. It would seem I have not.
Thanks, DEWFPO
Unused 2025 40ft. Texas Pride FT835524KGN 13 Ton T/A Gooseneck Flatbed Trailer (A49346)
Unused 2025 40ft...
2016 HITACHI ZAXIS 210LC-6N EXCAVATOR (A51242)
2016 HITACHI ZAXIS...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
Skidloader Bucket W/Hydraulic Attachment (A50774)
Skidloader Bucket...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
2022 JOHN DEERE 317G SKID STEER (A51242)
2022 JOHN DEERE...
