This Was NOT An Accident
/ This Was NOT An Accident #21
Thats probably a good idea. ... Those darn picky people who comment when something is off by only a factor of 2.
larry
Spyder...Did you see that tree....? If I had done all that work with that tree I would have posted that it weighed 500,000 lbs...I am sure it would have seemed like that...It was huge..:laughing:
/ This Was NOT An Accident #22
After the first few pops, that ol' tree sure groaned loudly as it came down. I don't know who it was screaming, "AWESOME!" after it was on the ground, but they sure were excited.:laughing: Nothin' like having your own cheerleading section nearby.;):thumbsup:
/ This Was NOT An Accident #23
Yeah, it sure was. I worked with a tree of similar size [40" red oak] harvesting it for firewood after it was put down for a development. As I split it, each 22" section took several high loaded wheelbarrows to transport and each seemed a woodpile unto itself. I weighed one of the larger pieces as a total of its split parts. --- 880lbs. Boy, did it split and stack nice! :)
larry
/ This Was NOT An Accident #25
Not a bright idea to use a boom to lift things out of the ground.. Must have been a good sized limb. Hopefully the guy will be ok. Those kind of injuries can kill you from internal bleeding and concussions.
/ This Was NOT An Accident #26
WHAT :mad: :mad: !!!! ARE YOU SAYING SOMEONE IS EVEN THINKING ABOUT DRILLING OR WELDING ON A ROP ? :mad::mad:
Just kidding :laughing: :laughing: :laughing:
Wait..... What is a ROP?
Jacen........
That was my 9 year old grandson screaming "AWESOME" in the background. :D
BTW - GRAVITY is an AWESOME thing.
/ This Was NOT An Accident #30
My wifey's grandfather used to burn out stumps. I think that is how they cleared their farm land back when they still where using mules to plow.....
I have seen him burn out large 36inch stumps from trees around the farm house. I do NOT know how he did it though. :D He is long gone so I cannot ask him. Sure wish he was still around so we could talk some more....
My only guess is that he let the stump dry out and/or soaked the stump in fuel before burning. What ever he did worked though.
I have tried and not had much luck. :D
Later,
Dan
/ This Was NOT An Accident #31
Have you tried boring the holes in the stump and filling with diesel fuel until it is soaked up? You can bore a hole sideways, or 45 degree angle toward the center. Then set some charcoal at the bottom holes and light. After burning good, place a fan or blower on the charcoal and stump , and the stump will burn inward and up. The fan or blower will add extra oxygen to the fire. Sort of like a forge.
Dan, I have successfully burnt out a couple of old well rotted stumps that were a few years old by just dousing them with diesel fuel and allowing it to seep and soak in for a couple hours prior to lighting it up with some mineral spirits.
It takes a long time for it to slowly smolder underground down the cambrium into the roots so is kinda dangerous because the root ball burns slowly for so long.
All I really need is to get it down below ground level a little so I can simply put a load of sand over it for cover and filler.
J.J., one of those 110 mph leaf blowers will fan one heck of a fire for ya like you described! :D
2010 CATERPILLAR 120M AWD MOTORGRADER (A63276)
2010 CATERPILLAR...
Conveyor Belt (A64194)
TROY-BILT GENERATOR (A64553)
TROY-BILT...
2021 John Deere 4044M (A64126)
2021 John Deere...
SHOP BUILT TRI-AXLE LOWBOY TRAILER (A63291)
SHOP BUILT...
HD Bale Ring (A66408)
