Sickle Bar This sickle bar mower worth anything?
   / This sickle bar mower worth anything? #11
</font><font color="blue" class="small">( Tag was pretty worn except for 'made in Netherlands' or something like that. I couldn't find the manufacturer on it anywhere. I'll try again on the picture upload. )</font>
If you are serious about identifying it, 'something like that' really isn't good enough. Or we could say it looks something like a hay mower & leave it at that. /forums/images/graemlins/wink.gif;) Just having some fun.
Most implements have a small metal tag on them with a model & serial plate. These plates are on the frame, which you have. Look close, in protected areas.... The CM 240 & the place of manufature is a good clue. Any other words, partial words, you can get off that sticker will help. The frame to cover over the blades makes me think it is a disc mower. Vicon makes disc mowers, so that's a good direction to investigate....
Around 'here' you can get a good sickle mower for $300. A good disc mower goes for $3000.
Unfortunately, you have the frame, and are missing the spendy working parts. I'd think you might as well consider it worthless scrap iron..... Now, if you happen to buy a working 240 Vicon, you'll have a few spare parts....
--->Paul
Found the blade attachment in the junk pile. It's a disc mower. Did some googling and found CM240 to be disc mower made by Vicon, which as I understand is out of business. The disc bar was pretty rusted out, and although I consider myself sort of handy in fixing things, I reckon this one is pretty much scrap. Since steel is at such a premium now, I guess it'll be off to the scrap yard for a few bucks. I've decided I'll only be haying about 8 or 9 acres, the rest will be in managed grazing, so I'll probly just have my cousin hay for me and patiently wait for those killer deals at a farm auction or whatever and start accumulating the equipment over the next couple years. Thanks for the responses!
Dave
   / This sickle bar mower worth anything? #13
Vicon is now part of Kverneland group.
Your mower can be older sister of todays CM series.
Their products are extremelly expensive, but worth a money.
Hope this helps
Outstanding! Thanks. I emailed the rep in MO here to see if parts might be available. Man, that would be a bonus.
Dave
   / This sickle bar mower worth anything? #15
I'm big fan of Vicon implements. I own their fertilizer spreader, and it is now in rebuild phase.
Contacted Vicon and got a lukewarm response referring me to 'ACI Distributors' (I think was the name). I looked them up and emailed them. Got a friendly response to let me know that almost all of the cutter bar parts are available as replacement from the factory. I also found an aftermarket parts supplier through and old tractor BBS in case the factory wants too much money. I guess these things had problems with welds near the root of the cutter bar and also had a tendency to lose the oil in the bar as well. I've got it ripped apart. Previous owner had replaced all the gears and gave up, thus saving me a huge rebuild expense. Pretty much all I need are a few bushings, gasket, and gear seals. Might also order a couple sets of blades. Last question if anybody is still out there. It has a guard but no curtain. I've heard these things throw rocks like a madman. My only haying field is a little 8 or so acre plot that the previous owner had in pristine condition (good grass, no rocks, no bumps, no errors, blah blah). If I cut without the shroud, am I being an idiot??
Thanks in advance.
Dave
   / This sickle bar mower worth anything? #17
</font><font color="blue" class="small">( If I cut without the shroud, am I being an idiot??
Thanks in advance.
Dave )</font>
I don't mean to be blunt, but:
Yes.
Keep us informed, I've enjoyed this thread. /forums/images/graemlins/smile.gif
--->Paul
2023 Kubota Z252KH-54 Zero Turn Mower (A56435)
2023 Kubota...
1298 (A58374)
1298 (A58374)
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2015 Hoist P360 36,000lb Diesel Forklift (A55973)
2015 Hoist P360...
2014 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A58018)
2014 FREIGHTLINER...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
