3-Point Hitch This Is A Test! Yesterdays post LOST
   / This Is A Test! Yesterdays post LOST #1
TomDetweiler
Grass Valley CA
ferguson to-30
Posted a thread yesterday about a '52 TO-30 with frozen "one touch" quad control lever.
Not here today so not sure what happened, either. Will try again to share info:
To save time, removed the control lever assembly (4 bolts in lift housing, comes right out).
It was totally rusted stuck. Worked at it several hours after drenching it overnight in Liquid
Wrench, tapping, heating, hammering, not one bit of movement. After more LW overnight
last night, finally gave up and took it to the local machine shop attached to our Riebe's Auto
Supply, where the guy used a tonnage Press to extract the frozen shaft from the housing!
$25 later I walked out with it in two pieces, finally. This saved me a lot of time, grief and
most likely busted knuckles and a lot of Blue Air around me.
When I removed the assembly, there was a hole in the top of the shaft housing, but no
evidence of lubrication unless you include rust in that category. I'm not sure how this shaft
assembly, with no bushings or bearings, is supposed to stay moving without lube but it did
work for me until now, and it's a 1952, only a few years younger than I am!
Will fill the shaft full of oil, put a big glob of grease on the dogleg/crank and put 'er back in.
Ought to work a whole lot better!
   / This Is A Test! Yesterdays post LOST #2
Great deal and probably the best $25 you ever spent.
Yep You Bet!
Found also there is no bearing or bushing in that assembly. Probably it's supposed to be pulled, filled with
grease or oil and bolted back in but there's nothing in the maintenance manual about it, at all. Oops!
I have a Zane Thang mechanical feedback rod on it too, and it will very likely work a whole lot better.
Hope the weather is OK for you in Nova Scotia, but I suspect you are getting quite cold already.
Tom in GV CA
   / This Is A Test! Yesterdays post LOST #4
Whatever it takes to get it working.
Weather is still warm,we don't see snow until after Xmas these past several years. Daily temps here around 65-70 degrees F, 18-20 degrees C. Global warming my friend, Nova Scotia is the new Florida.
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH636...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2017 RAM PROMASTER 2500 CARGO VAN (A51222)
2017 RAM PROMASTER...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A50397)
1989 Freightliner...
2017 Dodge Grand Caravan (A50324)
2017 Dodge Grand...
