Price Check third function.
/ third function.
Hey guys while we r kinda on the subject, would a diverter valve have enough flow to run a hyd. post hole auger? Or is that where the true third function is better? Or would either be just fine? :confused3:
That is a good question surely someone knows?
/ third function. #22
Some people are not handy or knowledgeable and want someone to make up a kit exactly for their tractor, and if they want to spend that kind of money, then so be it.
I just can not see the money in the kits.
I added rear hydraulics with the JD kit for my tractor specifically because I'm not up to speed on hydraulics. I'm still a hydro newbie, but I've been reading the Vickers Hydraulics manual and looking forward to the next project.
I would like to use the rear controls for top 'n' tilt and add a 3rd function for a grapple. I would love to save some $ and buy parts, rather than a 3rd function kit. Anyone know of a parts list, DIY blogs, etc. for adding a 3rd function from parts rather than a kit?
/ third function. #23
Say you have 11.8 GPM and an 18 in shaft on a 3 in cyl on the grapple.
The extend speed would be about 2.83 sec, and retract would be about 2.14 sec. That is fairly quick.
Well, 1 of 2 possibilities:
1. The Kubota 3rd function kit I had included a hidden flow restriction.
2. This isn't an issue in practice.
The grapple function never worked faster than I could handle. Now, realize I was using a GST tractor. I rarely set the rpm very high and used the foot throttle to maneuver the tractor and speed up the hydraulics when necessary.
ac
/ third function. #24
The one problem with your calcs is that as far as I know of anyway, :confused3: no grapple uses 3" dia cylinders. Smaller dia cylinders are normally used and so the movement should be quite a bit faster. (I think) :eek:
I agree, I used that example as the extreme. And yes, it would be faster.
Don't know why avc8130 grapple was slow.
Cylinder Speed single cyl
Bore Size 2 inches
Rod Diameter 1 inches
Pump Flow 11.8 GPM
Extension Speed 14.5 inches per second = 1.25 sec
Retraction Speed 19.3 inches per second = .93 sec
/ third function. #25
Chickengrower,
If the valve is sized for the flow in GPM, any type valve will run the auger.
You can use a selector valve, a true 3d function, or remote valve.
/ third function. #26
3ed function parts for grapple
Surplus Center - 12 VDC 10 GPM OC DA SOLENOID VALVE
Surplus Center - 1 STATION DO3 SUBPLATE OPEN CENTER
Selector/diverter valve for grapple.
Surplus Center - 12 VDC 13.2 GPM SAE 8 DOUBLE SELECTOR VALVE
http://www.surpluscenter.com/Instruct/I9-7852.pdf
Plus hoses, wire and switches.
/ third function. #27
Thanks JJ! You da man! :thumbsup::wave:
/ third function. #28
Bore Size 2 inches
Pump Flow 11.8 GPM
JJ,
I can't argue with the math, it is sound. Again, I didn't usually run the grapple at full rpm. I also had 2 cylinders on my grapple.
It could also be noted that Everything Attachments, WR Long and Kubota all sell 3rd function kits. I don't believe ANY of them have any flow restriction. Lots of happy users on these forums and I don't see anyone complaining about how fast their grapples operate.
ac
/ third function. #29
/ third function. #30
/ third function. #31
I will bet you did not read the description on that valve.
12 VDC HYDRAULIC SOLENOID VALVE
Brand new, EATON-VICKERS DG4V-3 series, double-solenoid control valve. Spring centering spool. Manual override on solenoids. Subplate mounting requires D03 subplate (sold separately) for port connections. Use with two Hirschmann connectors (sold separately) for wiring.
SPECIFICATIONS
Open center spool
Work ports blocked in neutral
Model DG4V-3-8C-VM-U-G7-61
Voltage 12 VDC
Amperage 3.5 Amps
Flow 10.5 GPM max
Pressure 3,000 PSI max
Use with D03 subplate
Size 8-3/4" x 1-7/8" x 2-1/8"
Shpg. 6 lbs.
The grapple will stay in the position that it is in when the valve goes to spring center.
/ third function. #32
SPECIFICATIONS
Open center spool
Voltage 12 VDC
Amperage 3.5 Amps
Flow 10.5 GPM max
Shpg. 6 lbs.
Cool, I'm still trying to learn the lingo for all of this stuff. Admittedly, I have learned most of it from reading YOUR posts. I just learned that a closed center wouldn't work at all on our hydraulic system since it would lock out the rest of the system when the valve was closed.
With the open center, but closed work ports will that valve be able to run a motor without pressure relief? I see they offer a motor spool version probably for exactly that purpose, but that would let the cylinders leak down and the grapple close?
ac
/ third function. #33
With a closed center hyd system, the will be a relief close by the pump. That is why closed center valves don't need reliefs on each valve, because they are all in parrallel.
The spool designed for controlling hyd motors is an open center type valve but is called a motor spool. This allows the hyd motor to free wheel with out damage.
Theoretically, you can run a hyd motor with a cyl spool, but you have to be careful, as the spools will close off the flow, and if the motor has enough centrifugal force and mass, the motor will act as a pump and the fluid has to go somewhere.
It is a good idea to add a relief valve across a hyd motor.
The Army hydraulics is a good reference/guide for for hyd knowledge, and there are many CD on line and web sites available.
Whatever hyd word you are searching for, you will find something. Save those articles PDF, and data relative to hydraulics.
/ third function. #34
ac
No, a closed center valve will not work on an open center system as there is no flow to tank until a hyd motor or cyl is activated.
However in a closed center system, all the valve are in parrallel, and all valves can be operated at the same time. The flow is divided among the operating valves.
If you use the open center cyl valve to operate a hyd motor, the motor will run and is protected by the relief valve on the valve, but before you go to neutral, the motor should be stopped.
Let me add some more data.
Some valves are convertible in the fact that it can be converted into an open center valve, or an open center with PB, or closed center valve.
/ third function.
Of the to what one requires less maintenance?
/ third function. #36
They (should) be the same---NONE. The diverter uses 1 single solenoid and the true 3rd function uses 2 solenoids. I have had to do ZERO maintenance with my diverters, the oldest one being right at 8 years old.
Nothing against true 3rd functions, I just don't see the need for them with the majority of work performed with the tractors talked about on TBN.
I personally don't see the need to be able to operate 3 functions at the same time unless you are in production and use this as part of making your living. Unless you have a 4n1 bucket, I don't see the need for it with just a grapple. These tractors don't have the GPM to move all 3 functions at a high rate of speed anyway. So unless you want to take a nap while you wait for all 3 functions to move, :rolleyes: or like running your engine at high RPMs, what good is having the true 3rd function?
You can always get the true 3rd function and just use it as a diverter, then you have the best of both options.
Just my opinion, I'm sure others will vary. ;)
/ third function. #37
/ third function. #38
Hello J.J.!
I tried a forum search on this valve and got 28 pages of threads!
I'm trying to find some plumbing info on this valve/sub-plate. Can the P and T ports be plumbed into the power beyond circuit between the loader valve and three point, or does it need its own pressure source?
Thanks,
ciderman
Boy you would think so, 3000 PSI on the valve and 5000 PSI on the sub-plate. I am no expert but I vote yes.
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
6' X 11' SHOPBUILT S/A TRAILER (A63745)
6' X 11' SHOPBUILT...
Snap-On Zeus Diagnostic Machine (A63118)
Snap-On Zeus...
2005 John Deere 6x5 Rotary Mower Tractor Attachment (A61572)
2005 John Deere...
2013 John Deere 825i Gator (A64047)
2013 John Deere...
